Question re: exhaust manifolds.
Old Jan 27, 2011 | 09:31 AM
chevypower91's Avatar
Car: 1991 Camaro Z28
Engine: 305 cid
Transmission: 5 speed
Axle/Gears: Posi/3:42
Hello,
I was wondering if anyone would know the part number for exhaust manifolds or would know if a set off a 350 would work with a 305.
The car in question is a `91 Z28, 305 cid.
Thanks,
Ben
Old Jan 27, 2011 | 10:33 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Question re: exhaust manifolds.
Yes
Old Mar 17, 2011 | 09:11 PM
Engine: 305 cid
I was wondering if anyone might have the part # for exhaust manifolds for a 305?
I am looking for a set for my '91 Z and I have found a pair that came off a '91 Z 350. The part # off the manifolds shows:
05200 RH 14094084RH
2130N LH 14094069
Thanks in advance.
Old Mar 18, 2011 | 07:42 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following from TransamGTA350, though it doesn't have p/n's, may be helpful. Note the size of the Y pipe):
There were only 2 different manifolds for the V8's throughout the years, but they were different depending on what motor and gearing package they came on. Here is the breakdown.
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
The manifolds from the single 3" cat and the dual 2.25" cats are interchangeable. On the passenger side manifold, some will have the heat riser butterfly valve, some will have a spacer, and some will just have a donut gasket. You most likely have the wrong manifold for your application. If you have the larger manifolds, then it may be worth it to get the larger y-pipe for some more performance.
JamesC
Old Mar 18, 2011 | 10:59 AM
Engine: 305 cid
82-83 305 Crossfire
88 350 L98 (VIN 8)
JamesC
Hey James,
Thanks for the info.
Based on the above, the manifolds for a dual cat set up are the same based on the diameter of the outlet, I am able to use the 350 manifolds on my 305 with no issues?
Thanks again for your help.
Benny
Vintageracer
Jan 10, 2020 05:33 PM
chazman
Aug 28, 2018 03:25 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
mustangman65_79
Aug 7, 2015 09:55 PM
