Will this work on my car?
Old Mar 17, 2011 | 06:22 PM
BowtieBandit13's Avatar
Car: 89 Trans AM
Engine: L98 5.7
Transmission: 5speed
I need to know if this will work on the stock manifolds.
http://www.summitracing.com/parts/DO...ize|5.7L%2f350
Old Mar 17, 2011 | 06:35 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Will this work on my car?
No, I don't think so ... it states "these kits are to connect DOUG'S HEADERS to a factory cat"
Old Mar 17, 2011 | 06:39 PM
Car: 89 Trans AM
Engine: L98 5.7
i noticed that it had a 3 bolt flange and stock manifolds have 2 bolts. is there somewhere i can get a replacement ypipe?
Old Mar 20, 2011 | 12:55 AM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
NEGATIVE on the stock manifolds.
There's another thread in the Exhaust section, where someone used this
as a more economical alternative to Hooker y-pipe for, use with Hooker
shorty headers, which I also have. So, on the strength of that, I got one.
Wound up having to cut/re-weld the drivers side flange. Not sure
where the ultimate problem was, but was less than impressed with
the effort needed to get everything all fit together.
Good luck.
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
TheExaminer
Aug 26, 2015 04:59 PM
jharrison5
Aug 19, 2015 05:53 PM
