Header Problems HELP
Old May 21, 2011 | 09:24 AM
Fermin91rs305's Avatar
Car: 1992 Camaro B4C
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
I installed Hedman Headers on my car about 4 days ago ran it at the track and it was a slower time. I was told that i could be that the tune is bad now. If i need a new tune which is best one for my car.
1992 Camaro B4C
5.7L L98 -
All i have is a cool air intake
Headers with 3'' exhaust - also took off the smog/air system and installed a idler pulley with a shorter belt.
Please if possible please help.
Old May 21, 2011 | 03:31 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
Re: Header Problems HELP
1992 Camaro B4C
5.7L L98 -
Which Hedman headers?
Old May 21, 2011 | 04:13 PM
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
68460 is the part number they are 3 collector and I have 3" exhaust all the way back...just want to see if anyone has had the same problem bcuz of their tune...I have a stock tune and have installed the headers and deleted the smog pump..
Old May 21, 2011 | 08:56 PM
85T/A350's Avatar
Engine: 350 Vortec
Im not for certain considering mine has no computer but I would say with the addition of long tubes, and deletion of the smog pump, that a retune would probably fix your issue.
Old May 21, 2011 | 10:41 PM
Engine: 6.2L
Transmission: TH400
Axle/Gears: 4.10
Okay I hope a retune fixes the problem but does anyone know a place to get a tune for a l98 5.7l 1992 camaro... I heard Pcmforless is good but they are not very descriptive on which pcm fits which cars. Anything will help thanks
Old May 21, 2011 | 11:21 PM
85T/A350's Avatar
Engine: 350 Vortec
You might post or check in the ecm or tpi section and get some more help there.
Street Lethal
Apr 30, 2019 12:14 PM
hectre13
Sep 8, 2015 03:38 PM
tricky1
Aug 23, 2015 01:17 PM
theurge
Aug 21, 2015 12:46 PM
sreZ28
Aug 14, 2015 07:48 PM
