Clearencing Headers?
Old May 30, 2011 | 11:47 PM
85T/A350's Avatar
Car: 1987 Pontiac Trans Am
Engine: 350 Vortec
I installed Hedman 68460 longtubes. They went in extremely easy from the bottom. But they do touch in a couple places. Ive seen several posts on using a hammer to dent headers to not touch, does this cause any negative side effects? I wouldnt think a couple small dents would hurt but Im not sure. Any thoughts?
Old May 30, 2011 | 11:50 PM
ymenic's Avatar
Car: 1982 Camaro z-28
Engine: 307
Transmission: th-350 with stage 2 shift kit
Axle/Gears: stock
Re: Clearencing Headers?
My header never fitted good, idk why. I always like to grind on A-arm mount or k member a little....why hurt performance...
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
i dented mine where they hit the k-member on the drivers side and saw no negative effects, car dyno'd 300rwhp/355rwtq
Old Jun 6, 2011 | 10:08 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
I notched my k-member where the tubes would hit.
You'll have clearance issues with or with out poly mounts too.
Old Jun 6, 2011 | 11:10 PM
85T/A350's Avatar
Engine: 350 Vortec
I decided just to use a hammer on the headers. It only took 2 small dents between the both of them. If they would have been a more expensive set of headers and I would have done something similar to what you did.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
