Help with flange stud. Its all broke n' stuff
Old Jun 8, 2011 | 10:41 PM
zz's z28's Avatar
Car: 1987 Iroc Z
Engine: 383 Mini ram
Axle/Gears: borg warner 9 bolt
So ive been driving around my 87 iroc 5.7 with an exhaust leak for a bit now.
I put it up in the air, and tried to tighten the drivers side exhaust manifold flange bolts.
I realized its loose because one of the studs is completely stripped.
Anybody know a good/easy way solving this issue?
the leak is so bad i cant drive the car without smelling like i just mowed the lawn.
I cant imagine getting a tap and die set would work too well without removing the entire manifold, which id like to avoid if possible.
ANY IDEAS?
Old Jun 9, 2011 | 12:30 AM
camaroinoh's Avatar
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: Help with flange stud. Its all broke n' stuff
Nothing easy about that drill and tap might be able to go though wheel well to get it done with out removing manifold but it its been leaking gaskets are shot so your going to want to remove it anyways time for an upgrade get some headers
Old Jun 9, 2011 | 08:02 AM
zz's z28's Avatar
Car: 1987 Iroc Z
yeah
. I had a feeling it was near impossible. Thanks for the input!
no green
Jan 9, 2016 09:22 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
