My exhaust fab! - Long tube headers and lots of ground clearance!
Old Jun 18, 2011 | 04:46 AM
  #51
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Re: My exhaust fab! - Long tube headers and lots of ground clearance!
Originally Posted by scooter
Well think a little harder about what you told me the other day about the Corvette sitting in my driveway, I hadnt thought about that either.
I can think of maybe one way to attempt to make oval tubing but it would be a pain in the *** and obviously this guy has it figured out, maybe it is easy too but we will never know. Not to mention the only way I can think may distort the tube out of whack or not work at all.
This guy gave an awesome play by play of how he made his own sub frame connectors too, doesnt make sense why he wont share something else cool, guess he wants to sell his "kits" and make a ton of money since it is expensive to buy from other places.
I'm willing to bet that straight sections could be made without too much difficulty, if the tubing is packed with sand first....
However, doing bends would take a bit more trial and error, at least for me
I would probably end up making bends by cutting the tubing at an angle and welding, multiple times if necessary. Hmmm
Old Jun 18, 2011 | 01:26 PM
  #52
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
If your referring to oval (I didn't use sand) I don't think sand would work as you would be decreasing the volume of the tube and creating a lot of pressure more so then doing a mandrel sand bend which is really just stretching the outer radius of the tubes material which is another reason why you want to heat the area being bent to decrease the risks of tearing especially with how thin walled exhaust tubing is. The pressers involved would be like trying to oval a solid round bar stock to oval, easy to bend into shapes near imposable to oval... This is just my speculation of corse
Old Jun 20, 2011 | 12:19 PM
  #53
FueledSoul's Avatar
All complete! other then i still have to fab up the front hanger.
I ground down ALL the welds and sanded everything to a nice over all finish.
Since everything is off the car i figured this would be a good opportunity to lay it all out and take some pics, the plastic is still around the muffler along with the bubble wrap on the tail pipes i left them on to keep them from getting messed up during the install...
Old Jun 20, 2011 | 10:17 PM
  #54
88gunmetalgta's Avatar
What do you have in mind for the front hangar? The factory one from the transmission tailhousing sucks!
Old Jun 20, 2011 | 11:29 PM
  #55
FueledSoul's Avatar
Cant be factory anyway, I'll have to fab something up. I have some peaces left over from some other magngaflow kits iv installed on some other cars that i might make use of but we'll see. Im most likely going to mount this on the trans/floor pan area and have something welded or attached to the y-pipe transition or the front of the 3" cat-back tube.
Old Jul 5, 2011 | 01:07 PM
  #56
FueledSoul's Avatar
Cleaned and coated the inside of all the tubes.
Old Jul 6, 2011 | 04:52 PM
  #57
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Mind sharing details on the how and which products used for this? Love how yours turned out, I'd like to do something similar down the road.
Old Jul 7, 2011 | 11:58 PM
  #58
GOTCHEVY's Avatar
Car: 97 Z28
Engine: 396 LT1 518whp All Motor
Transmission: 6spd
Axle/Gears: 4.10 LSD
Great f*ckin exhaust dude.....
Old Jul 11, 2011 | 09:06 PM
  #59
stiers's Avatar
Looks great! Nice job!
Old Jul 11, 2011 | 09:13 PM
  #60
FueledSoul's Avatar
Resists Temperatures up to 1300degreesF. Forms a Hard, Lasting Finish that will not Burn Off, Chip or Peel. Ideal for use on Headers, Exhaust Manifolds, or any Surface Exposed to Very High Heat.
Thats all i used just read the directions on the back of the can. It holds up well iv used this product before with good results
Old Jul 11, 2011 | 09:14 PM
  #61
FueledSoul's Avatar
Thanks!
  #62
FueledSoul's Avatar
Thanks!
Old Jul 11, 2011 | 09:51 PM
  #63
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Does this hi temp paint actually work? They have a nice selection of colors but i've always been skeptical about these aerosol hi temp paints.. What is the curing process? I don't really have access to an oven that can bake headers, if that's what it requires?
Old Jul 11, 2011 | 10:20 PM
  #64
FueledSoul's Avatar
Yes, hi temp paint works. I was also extremely skeptical but for the price it was worth trying out. Here is my experience. I had a set of headers media blasted to bare metal, cleaned and prep then coated them in high temp same brand and color and installed them on the car a few weeks later (can says to heat cure them in a hour after coating or something i don't have the can handy to read it ) but it bubbled in a few spots but it still cured and was very durable i think it was a combination of rapid high heat and the fact your suppose to cure then in a certain time frame. i was somewhat disappointed but next round on some other parts i followed the instructions on the back on the can to a T and baked the parts and they never chip, bubbled, cracked etc id compare the durability to a true ceramic coat they even looked pretty nice too. I think as long as you follow the cans directions it will work just like they state on the can. after i painted the inside of the tubes on my exhaust system i followed the on car curing instructions and im sure they cured just fine i have to pull them down soon anyways so all look and i can post results even if they bubbled in spots or whatever i don't care to much i just wanted to add a layer to keep the inside exhaust temps up and the outside down. If you search on the web you'll find a lot different forums, post and threads regarding rattle can high temp and as far as i could compile baking parts is the the way to go
Old Jul 11, 2011 | 11:20 PM
  #65
Everything is in the prep for any paint, this one seems to be no different. I was thinking of doing this AND installing header wrap. Keeping the heat down is crucial and also makes less heat fly in my face while i'm driving. So you didn't bake them in an oven and just cured them on the car?
Old Jul 12, 2011 | 12:13 AM
  #66
FueledSoul's Avatar
Of course it is but as you read even the amount of prep i did was no match and still bubbled besides the fact i waited a few weeks to put them on after painted (the can says to cure them within a hour of coating if i recall) i think in the end that's why it bubbled but i also suspect the rapid high heat on the primaries too because as i re-count a buddy of mine had the same thing happen even cured them with in the given time frame... eh not a fan of warps and have no idea how the will the paint will work covered in warp. I cured them on the car following the cans directions
Old Aug 12, 2011 | 12:41 AM
  #67
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Can I see the Ball/Socket Bends that bolt to the HEADERS, The Ones that angle slightly downward to clear the Transmisission/Transmission Crossmember. Can I purchase these already made, or custom only? Thank You.
Old Aug 12, 2011 | 10:55 AM
  #68
FueledSoul's Avatar
They already sell them in pain steel... are you looking for stainless?
Old Aug 12, 2011 | 11:22 AM
  #69
Either material is fine, preferably Stainless Steel. Where can I purchase said pieces, specific name? Thank You.
Old Aug 12, 2011 | 11:24 AM
  #70
FueledSoul's Avatar
No one that i know of makes them in stainless i had them done...
http://www.summitracing.com/parts/HED-21115/?rtype=10
Old Aug 13, 2011 | 09:10 PM
  #71
Yes those are the reducers that are included with the headers, I'm referring to the piece you welded to it. It's like a 22 degree bend... Thank you.
Old Aug 14, 2011 | 12:18 AM
  #72
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
dub post
Old Aug 14, 2011 | 12:20 AM
  #73
TTOP350's Avatar
Why wont you share? I have contemplated the oval tubing but I am completely put off by the price from the manufacturers, if this was something easily replicated by the DIY'er could save your fellow members a LOT of money
Its easy to do with a hammer and a few 2x4s or you could just man up and buy it.
http://www.burnsstainless.com/304ovalsstubing.aspx
Old Aug 14, 2011 | 12:29 AM
  #74
TTOP350's Avatar
For the one i did on my car I used a simple hanger (with a rubber mount that has a hole) off of the old trans exhaust mount point. Weld a cross bar between the Y with a upside down J going up to the rubber mount its really simple and works great..
This explination of what I did sucks..
Old Aug 14, 2011 | 12:32 PM
  #75
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Yeah and it would look like complete dog crap. Somehow this guy was able to do it and make it look nice, but wont share that butposts a step by step on SFC's that looks awesome
I have been looking at Burns Stainlless for years now, I dont like their transitions, not to mention the cost.
You arent showing me anything new smartass
Old Aug 14, 2011 | 05:01 PM
  #76
87350IROC's Avatar
Car: 87' IROC
Yes, if prepped and carefully cured, the paint will last. Mine has lasted very well for the last 7 years. I lightly sanded, cleaned thoroughly with alcohol, and sprayed two very light coats of paint on the headers. I then let them sit for a few days. Finally I cured them on the engine. Run engine for 1min turn off and let cool to ambient. Next run for 5 mins and let cool to ambient. Finally run up to operating temperature and turn off, let cool over night. Done.
The paint has dulled some over time, but it still looks good.
Old Sep 10, 2011 | 08:50 PM
  #77
FueledSoul's Avatar
Finally got time and got the front hanger done
I had some left over parts from some other mangaflow systems
Old Sep 10, 2011 | 08:55 PM
  #78
FueledSoul's Avatar
Plate for the inside...
pulled off the car and welded the tab
Old Sep 11, 2011 | 03:16 AM
  #79
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
You talking about the S-extensions?
http://www.summitracing.com/search/D...er-Extensions/
Old Sep 12, 2011 | 10:52 AM
  #80
Those are the ones, I actually recieved them last week. Unfortunately they sent me the universal fit, I needed the Ball and Socket. Sending them back today. I also had a local muffler shop make me one. I explained to him what I wanted and the approximate degrees of the bends. The guy charged me $35.00 for one, that's with those nasty dents the tube bender left. Live and Learn and Spend Money...
Old Sep 12, 2011 | 10:02 PM
  #81
84 Kamp311's Avatar
Car: 1984 Camaro Z28
Engine: 406
Transmission: TH400 3K stall
Axle/Gears: DTS 12 bolt 3.73 eaton posi
Re: My exhaust fabrication! - Long tube headers and lots of ground clearance!
this is what I have dougs long tubes 3'' y pipe to 4'' flowmaster take a listen
408 small block thumper cam custom 4" exhaust on a 3rd Gen camaro on you tube
Old Sep 12, 2011 | 10:20 PM
  #82
84 Kamp311's Avatar
Engine: 406
this is my custom made 3" y pipe to 4" over the axle to flowmaster with sound
Attached Thumbnails My exhaust fab! - Long tube headers and lots of ground clearance!-y-pipe-no-muffler.jpg   My exhaust fab! - Long tube headers and lots of ground clearance!-y-pipe-car-showing   My exhaust fab! - Long tube headers and lots of ground clearance!-y-pipe-w-muffler.jpg
Old Jan 7, 2012 | 03:54 PM
  #83
FueledSoul's Avatar
Sounds nice looks nice!
Old Jan 8, 2012 | 07:42 PM
  #84
God I hate our WI hobbyist plates..... They clash with any paint scheme. Nice exhaust tho!
Old Mar 11, 2012 | 06:32 PM
  #85
heavychevy8492's Avatar
A vise ..that's all u need well 2 vices ..then u can make oval pipe ...some secrets still omitted but yall should firgure out the rest easily ..
Old Mar 12, 2012 | 02:43 PM
  #86
FueledSoul's Avatar
I don't know about pipe ovals, never tried to oval pipe... however I do know about oval tube and a vise will not make a good form for oval tube... you can try but all you'll be left with is tubing with a crashed / indented roof and floor and pointy round ends that have a bad radius... I posted a chart showing round to oval if you try to duplicate the dimensions on a vise its not going to happen good luck...
Old Mar 12, 2012 | 09:20 PM
  #87
I made my dies out of aluminum ..placed in the vice ...works very well ..i work as a tig welder at a stainless fab shop ..had our machineist help me out ; )
Old Jul 17, 2012 | 02:27 PM
  #88
84 Kamp311's Avatar
Engine: 406
looks really good, check this out, Im running 1 3/4 long tubes also, Dougs. 3" into 4" over the axle into a 4" flowmaster race muffler.
Old Aug 17, 2012 | 10:59 PM
  #89
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
Hey fueledsouled how did that custom flange you made work did it leak? I can't find a 3" flange for my ball and socket shorty hedmans and thought about flaring out pipe to work lol
Old Aug 25, 2013 | 03:35 AM
  #90
dragster350's Avatar
I put together my own kit and i sell them too...
2.5" stainless full mandrel bends
Here's the start of the Y
So to gain ground clearance i looked into oval tubing...
Oval tubing
To damn expansive so i decide to hit the drawing board and i came up with my own forming process, the first forms i made worked ok, i brought dad aboard to help me fine tune the form... and thus oval tubing was born from round! the oval came out just like the diagram above...
This isnt the best pic but you'll see better ones, i had to do a round to oval transition right away to gain extra ground clearance right off the bat.
how much do you sell the kits for
Old Nov 1, 2013 | 09:28 PM
  #91
j88l98irocz's Avatar
Car: 88 IROC-Z twin turbo
Engine: forged 383 8-1 compression
Transmission: t56
Axle/Gears: 9in 3.50's trac loc moser axles
Nice work!
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
customblackbird
Aug 15, 2021 10:16 PM
italiano67
Dec 11, 2016 09:21 AM
