My exhaust fab! - Long tube headers and lots of ground clearance!
Old Jun 10, 2011 | 10:13 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Most will probably picture read, but all post some info anyway that maybe helpful for someone.
Headers
Im running long tube hedman Hedders Part#68460.
My first set of long tube hedmans where undercoated i had them blasted and ceramic painted. When i installed them some of the header primary where hitting the k-member, i marked the sport that where hitting then i cut the material out of the k-member and welded in patches. Im glade i went with a cheaper undercoated set for the "test fit". later on i went ahead and ordered the same set from jet hot in there 1,300 degree sterling silver.
FueledSoul's Avatar
Re: My exhaust fabrication! - Long tube headers and lots of ground clearance!
Old Jun 10, 2011 | 10:14 PM
FueledSoul's Avatar
Fast forward: The car really has ran much since iv been working on other things the car has been kept indoors and i see some of the jet-hot coating is getting what appears to be surface rust SMALL but i see it! so much for spending up words of $600 for a set of headers you thought would last.
anyways rather then bitch about it i started to buy parts to fab a y-pipe but before i started on the fab, i did i what iv been wanting to do! switch out my rubber motor mounts! I originally planed on it but right after i put all my front suspension back in and made my way to the motor mounts, i realized that they are fastened by nuts and bolts i figured they would be welded nuts like the transmission cross member - WRONG so about a month ago i pulled most of all the front suspension back off to access the 6 nuts on the bottom of the K-member, see another reason why i really wanted to switch these out is i wanted the motor to sit like its spouse to before i built the y-pipe and to correct any issues before hand. I went with poly for the engine and transmission.
also since i had most of the front end parts off I spent about 7 hours prepping and painting the front of underside, everything else was previously painted as you can see...
This is all i got for pics of the front for the moment.
Getting ready for the poly mounts clam shells painted.
FueledSoul's Avatar
I permanently welded all 6 nuts to the k-member, so much easier to do mounts wish i did this when i had it all apart before!
I got the poly mounts installed, Im glade i did seems it corrected some issues, The headers have more clearance on each side since the engine sits 1/8" to 1/4" higher.Even with these mounts one would still have to modify the k-member and a-arm pockets for the headman long tubes!
Here is a comparison.
Old Jun 10, 2011 | 10:15 PM
FueledSoul's Avatar
Here is how shitty the rubber mounts were.
passenger side.
driver side.
Old Jun 10, 2011 | 10:33 PM
FueledSoul's Avatar
Before getting to the y-pipe:
I had bought a 4thgen magnaflow cat back several years back before they seen any popularity in the thirdgen community, i had one on my 4thgen Camaro and liked it...
All stainless 2.5" and 3"
I bought new factory style thirdgen hangers and a 4thgen 93 - 97 v6 hanger? here is some pics the part numbers are on the boxes. i had to modify the brackets to get them work but it was easy.
Old Jun 10, 2011 | 10:38 PM
FueledSoul's Avatar
Test fitted...
Some shots of the clearance
Old Jun 10, 2011 | 10:51 PM
FueledSoul's Avatar
I had to correct the angle of the cat- back tube so i marked it and notched and tact it in place it it it worked great and the angle was how i wanted it.
I also had to cut the tube back to clear things for the y-pipe.
I took about 8" to 12" off of it... after trimming it here and there to test fit
Old Jun 10, 2011 | 11:02 PM
FueledSoul's Avatar
Y-pipe:
After the cat-back was pretty much where i wanted it... i turned to the Y-pipe. I ran into a road block with trying to find someone to make a stainless socket so i could match it up to the headers ball. I even emailed hedman and they where No help! competently disappointed! but after driving to several exhaust shops i was able to get something close and im sure it will leak but all deal with that later on. Sad you spend all this money on stainless and cant even get a stainless reducer. another thing is i wish hedman made 3rdgen headers in stainless.
Old Jun 10, 2011 | 11:17 PM
FueledSoul's Avatar
I put together my own kit and i sell them too...
2.5" stainless full mandrel bends
Here's the start of the Y
So to gain ground clearance i looked into oval tubing...
Oval tubing
To damn expansive so i decide to hit the drawing board and i came up with my own forming process, the first forms i made worked ok, i brought dad aboard to help me fine tune the form... and thus oval tubing was born from round! the oval came out just like the diagram above...
This isnt the best pic but you'll see better ones, i had to do a round to oval transition right away to gain extra ground clearance right off the bat.
Old Jun 10, 2011 | 11:31 PM
FueledSoul's Avatar
Starting on the passenger side,
i had to modify my UMI transmission cross member...
Round to oval then back to round.
At this point i temporarily put up my 10 point sub frames to make sure i wouldn't run into any issues. Here what they look like if you never seen them
I built them awhile back, here is the link if you want to read and see more about them: https://www.thirdgen.org/forums/fabr...al-design.html
Passenger all tacked up.
Old Jun 10, 2011 | 11:54 PM
FueledSoul's Avatar
Drivers side.
i had to modify my UMI transmission cross member on this side too.
This side started out the same way as the other one side did round to oval right off the bat but i had more bends on the drivers side.
Old Jun 11, 2011 | 12:00 AM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
ouch that exhaust looks like it is going to hang low.. I would of notched the crossmember to gain ground clearance, over go over the top of the crossmember. Nice looking tho
Old Jun 11, 2011 | 12:04 AM
FueledSoul's Avatar
I had a harder time connecting the front header peace to the y-pipe transition so i measure points on the rockers and the tube centers and did some math and laid out the points on cardboard so i could have an idea what would work. it was so simple i was able to know what bends would work and where to mark.
Old Jun 11, 2011 | 12:05 AM
FueledSoul's Avatar
LOL, i did notch. you cant go over the top of the cross-member. re-look at this post.
Old Jun 11, 2011 | 12:07 AM
FueledSoul's Avatar
Y-pipe all fab up.
Old Jun 11, 2011 | 12:19 AM
FueledSoul's Avatar
Just for fun i put the car back on the ground and rolled to settle.
NOTE:
1) 255/45/16 tires at the time of these pics they all had 32lbs of air.
2)
1.6" drop springs up front. 1.4" drop springs out back
3)
No front hanger at the time of these pics the front hanger would give me half of inch more clearance
Currently the lowest point of the exhaust, remember this is with low tire pressure and no front hanger over 4" 1/4.
Old Jun 11, 2011 | 12:57 AM
FueledSoul's Avatar
More to come...
Old Jun 11, 2011 | 04:43 PM
chevman24's Avatar
Car: 88 and 02 Camaro's
Engine: L96 (LS) and LS-1
Transmission: auto, 6 speed
Axle/Gears: 3.42 gears for both
Thats plenty of exhaust ground clearance. I have about 3 inches between the ground and my Y-pipe on my 4th gen and rarely ever hit.
Old Jun 11, 2011 | 05:51 PM
Shadow Z's Avatar
Car: Lots of 'em
Cool build man. Feel like doing mine?
Old Jun 11, 2011 | 06:05 PM
one92rs's Avatar
Car: SOLD!!!!!
so i have to know. how did you do the oval tubing.
Old Jun 12, 2011 | 11:01 PM
FueledSoul's Avatar
exactly
Old Jun 12, 2011 | 11:02 PM
FueledSoul's Avatar
thanks, not really hahaha
Old Jun 12, 2011 | 11:03 PM
FueledSoul's Avatar
I made a form.
Old Jun 12, 2011 | 11:13 PM
FueledSoul's Avatar
Re: My exhaust fab! - Long tube headers and lots of ground clearance!
I had to modify one of my sub frames to tuck the exhaust up more, i will have to come back to this and reinforce it.
Old Jun 12, 2011 | 11:24 PM
FueledSoul's Avatar
Pulled it down so i can fully weld it. I will be using 0.30" 304 stainless wire tri mix gas on a mig.
drilled the spots i per marked while the exhaust was still under welded all the bungs on.
Old Jun 12, 2011 | 11:34 PM
FueledSoul's Avatar
I was semi disappointed looking into my magnaflow transition,
As you can see theirs a ridge where the exhaust flow will run into...
I removed the ridge and bleat it in with one of my carbide burs and hit it with a few cartridge rolls, I also did this to the cat-back tube leaving it with a near knife shape edge since slip fits in side the transition
Old Jun 13, 2011 | 01:53 AM
88gunmetalgta's Avatar
Looks good!
Old Jun 14, 2011 | 12:25 AM
FueledSoul's Avatar
Originally Posted by 88gunmetalgta
Looks good!
I got your PM all send you one back sometime within the next couple days
Old Jun 14, 2011 | 04:16 AM
Primetime91's Avatar
Car: '88 Camaro (Gone...)
Care to share the "die" you made to create the oval tubing? I'd love to see it, really cool
Old Jun 14, 2011 | 12:16 PM
FueledSoul's Avatar
not really hahaha. but thanks
Old Jun 14, 2011 | 12:34 PM
FueledSoul's Avatar
This stuff is a amazing!
I might have to put another layer of protection on the fuel and brake lines the tube that comes down from the header is has a bit over a 1/4 of an inch from making contact with the lines
I never liked the factory heat shield...
Old Jun 14, 2011 | 12:42 PM
No rush man. My exhaust project is a ways off.
Old Jun 14, 2011 | 11:55 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Your Exhaust and Fabrication looks great! Congrats!!!
I did almost the same thing last year... (your workmanship is head and shoulders better than mine...)
https://www.thirdgen.org/forums/exha...y-new-3-a.html
I Love the oval tubing idea...
Your car sits way higher than mine and you have drop springs!!!????
Time for me to change my springs I guess... cause I still scrape. (Our roads suck a**)
Good Luck with the rest of your build!!!
Old Jun 15, 2011 | 07:14 AM
chevman24's Avatar
[quote=GTA Sammy;4952131]Your Exhaust and Fabrication looks great! Congrats!!!
quote]
That looks preatty good!! Only i think your exhaust tubing is too close to the transmission pan and to take the pan off would mean that you have to drop the exhaust to access the bolts.
Old Jun 15, 2011 | 09:11 AM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
8 bolts to drop the Y-pipe... 4 minutes tops.
And having the routing that close to the Tranny pan is the only way to keep ground clearance...
That's why I wrapped it in header wrap....
you can actually touch it with your hand....
But I digress, lets not take away from FueledSouls thread.
Old Jun 15, 2011 | 10:19 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Why wont you share? I have contemplated the oval tubing but I am completely put off by the price from the manufacturers, if this was something easily replicated by the DIY'er could save your fellow members a LOT of money
Old Jun 15, 2011 | 10:22 AM
chevman24's Avatar
I think its part of the thread and both exhaust systems are better than what i have. It was more constructive critism than anything. Both were done well!! Just my
Old Jun 15, 2011 | 01:35 PM
FueledSoul's Avatar
Thanks for the comments and complements. Yea, making the oval tubing gained me 1/2" more ground clearance which i feel was worth the extra time and effort. It could be more of a optical illusion some of the pics i had took the camera was on the ground pointed up. The car sits pretty low it has a 1.6" inch drop springs in the front and a 1.4" drop springs in the rear. Our roads suck as well...
Old Jun 15, 2011 | 01:50 PM
FueledSoul's Avatar
Your not taking away from the thread even if you where its not like we're falling off topic... I semi agree with chevman24 about the exhaust being close, but i do have to say tho how many times do you plan to pull your transmissions pan? Im not a fan of exhaust wrap in general, it does serve a purpose in some cases, in yours it will help keep heat away from the pan so i guess i feel pretty neutral about it. I will likely have to drop my y-pipe to unbolt my transmission crossmember and im not worried about it at all since i rarely need to drop it...
Old Jun 15, 2011 | 02:01 PM
FueledSoul's Avatar
I contemplated about oval before digging into this build, The pricing of oval tubing in my opinion is ridiculous, that is why i did quite a bit of trial and error in designing and making forms/dies. The time, effort and what i invested coming up with ways of replicating oval tubing isn't something im ready to share yet... I think to show you that oval tubing can be replicated in it shelf is sharing.
Old Jun 15, 2011 | 03:57 PM
  #42
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Great! Another JERRYWHO
Old Jun 15, 2011 | 06:13 PM
  #43
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
come on james, i can think of 2 or 3 ways to make oval tubing without even thinking hard.
Old Jun 15, 2011 | 06:15 PM
  #44
//<86TA>\\'s Avatar
Car: 86 Trans Am
good looking work FueledSoul! But from the pics, i dont feel the car is that low.either way, it looks good.
i kinda like the blue thing you have going under there. Any reason you didnt match the parts to the body color? or do you just like blue
Old Jun 15, 2011 | 07:19 PM
  #45
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Well think a little harder about what you told me the other day about the Corvette sitting in my driveway, I hadnt thought about that either.
I can think of maybe one way to attempt to make oval tubing but it would be a pain in the *** and obviously this guy has it figured out, maybe it is easy too but we will never know. Not to mention the only way I can think may distort the tube out of whack or not work at all.
This guy gave an awesome play by play of how he made his own sub frame connectors too, doesnt make sense why he wont share something else cool, guess he wants to sell his "kits" and make a ton of money since it is expensive to buy from other places.
Old Jun 18, 2011 | 01:02 AM
  #46
FueledSoul's Avatar
i have no clue what your talking about.
Old Jun 18, 2011 | 01:03 AM
  #47
FueledSoul's Avatar
Exactly...
Old Jun 18, 2011 | 01:17 AM
  #48
FueledSoul's Avatar
Thanks, the drop springs i put in did drop it about what it said it would (1.6F/1.4R) over the ws6 springs i had on it before so i dunno... I might drop it more but that depends on the wheels i go with in the future.
Matching things body color would be a little more costly. The real reason i went with blue beside the fact i like blues is everyone has red and black suspension peaces so having blue also adds a color contrast you have the body color being primary and blue being the complementary color...
Old Jun 18, 2011 | 01:26 AM
  #49
FueledSoul's Avatar
Whats your idea on doing oval that would be a pain in the ass? Its pretty easy just took some thought and trial and error to get it right. The subframe thread is probably one of the better write ups as far as subframes go for thirdgens. I just wanted to toy with people to see if they could figure out how to do oval... I think i hear knocking but no ones at the door... The kits i put together arn't oval nor will i be offering that you can sang one from me for $225 probably a better deal then you'll likely find anywhere else...
Old Jun 18, 2011 | 01:30 AM
  #50
FueledSoul's Avatar
Out of stock...
Took a month to get these stainless flanges in...
