Exhaust help!
Old Jul 15, 2011 | 11:37 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Exhaust help!
I just bought a thrush welded muffler for my 91 rs. The old mufflers clamps were on so tight that it crimped on to the tail pipes and intermediate pipes, so we basically had to wreck it to get it off, the new muffler works with 2.5 inch pipes, so the tail pipes fit how they should, my problem is that for some reason the person who owned the car before me put bigger tail pipes on but the intermediate pipe is still 2.25 inches, which won't fit into the muffler. I've looked everywhere and I can't find a muffler with a 2.25 in let, and 2.5 outlets, and no one has the right adapters that would fix the problem. So what so I do?
Old Jul 16, 2011 | 05:16 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: Exhaust help!
Adapters are available, look harder...
Old Jul 16, 2011 | 08:36 AM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Exhaust help!
I did look, it's like they have every size adapter except for the one I need
Old Jul 16, 2011 | 12:15 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Exhaust help!
Walker 41963, 2 1/2" O.D. to 2 1/4" I.D. Probably about $3.
Old Jul 16, 2011 | 05:42 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Exhaust help!
It needs to be 2 1/4 O.D., the pipe is 2 1/4 I.D.
Old Jul 16, 2011 | 05:56 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Exhaust help!
The intermediate pipe is 2 1/4" OD? You're positive about that?
Old Jul 16, 2011 | 06:00 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Exhaust help!
No, the pipe is I.D., which means the adapter needs to be O.D., which I can't find, and I used and electronic pipe measuring tool to measure them
Old Jul 16, 2011 | 06:14 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Exhaust help!
What if you try it with a caliper?
Old Jul 16, 2011 | 06:17 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Exhaust help!
I did (sorry, forgot the name of it) it had and electronic display to tell you what it measured
Old Jul 16, 2011 | 06:22 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Exhaust help!
I'd be really surprised if the pipe actually had a 2 1/4" ID.
Whatever, though... Walker 41918 if it is.
Old Jul 16, 2011 | 06:29 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Exhaust help!
I was surprised too, I wasn't the first one to measure it but when they told me it was I.D. I measured it myself cuz I thought it was wrong, but it wasn't
Old Jul 16, 2011 | 06:30 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Exhaust help!
What were the actual measured I.D. and O.D.?
Old Jul 16, 2011 | 06:37 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Re: Exhaust help!
I forget the exact numbers, the 2 1/4 mid pipe was measured ID tho
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
