1 7/8 lt's? Does anyone make these for the street???
Car: 91 RS
Engine: 408, 400 bored .40, afr 217 cc's
Transmission: 6 spd
Axle/Gears: 9 bolt 4.10's, 35 spline & spool
Hey fellas, am I just mental or how could aftermarket companies not make 1 7/8 lt's for 10 FEFFEN years for third gens???!!!
Ive looked but it seems only hedman makes them but you cant run ps, ac or other crap!! I did find stahn headers for like 1k but way to steep for me
Any help would be great!!
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: 1 7/8 lt's? Does anyone make these for the street???
I'm pretty sure you could make a set of 1 7/8" headers, but it'd take some fabrication. All the ones I've seen take adaptors for Stahl type bolt patterns.
Is there a reason you believe you need 1 7/8" primaries?
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
I know there are 2in ones out there
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
if 1k is too steep, might as well give up now... you will not find them cheaper than that.
Car: 91 RS
Transmission: 6 spd
unbelieveable....FML, ya ive seen some for over 1k just race only though
I aiming for the 600hp mark on my 400 bored .40 over 11:1 comp afr's etc... i have hooker 1 3/4 lt's just wanted 1 7/8's, every damn car has 1 7/8 lt's made by like 10 different companies. guess im just frastrated
booo
booo Joined: Aug 2006
Car: 86 Trans Am
its because of fitment, its hard to fit large diameter tubes around the stock steering AC box, k-member, ect.
Engine: 4++,350 & 305 CIs
There is a need for 1" 7/8ths and 2" headers..
Im looking at/for 2" for my car. The problem Im having is they have a 3.5-4 in collector, that may be over kill.
