dumb question
Old Jul 31, 2011 | 09:03 PM
protestthehero's Avatar
dumb question
I recently finished installing my hedman hedders along with the matching y pipe. i put in the o2 sensor on the collector of the drivers hedder. im currently running open y until i have the chance to weld in my cat. the "dumb" question is, am i supposed to have backfires? when the car is running, it runs fine. only when i go WOT and let off or when i free rev it somewhat high does it back fire. is this normal?
Old Aug 1, 2011 | 07:33 AM
torque_is_good's Avatar
Re: dumb question
is it BAM, a loud backfire when increasing rpm's or is it pop pop pop as you left off of the gas?
Old Aug 1, 2011 | 08:26 AM
Recaro trans am's Avatar
Car: 1985 pontiac trans am
Engine: Procharged 5.7l
Transmission: t-56
Axle/Gears: stock 9 bolt 3.71
Re: dumb question
Is your car carbureted? If so you have to remember that fuel will still be pulled into the engine when decelerating in gear. When this happens fuel vapor fills the exhaust and if the ratio is right you get a back fire. Usually a series of pops.
Old Aug 1, 2011 | 11:41 PM
Re: dumb question
my car is tpi. and when i let off the throttle it will pop pop and bam
Old Aug 2, 2011 | 08:04 AM
Transmission: t-56
Re: dumb question
It sounds like its just pulling fuel into the engine, blowing it out the exhaust and reigniting when it gets a bit of O2 on the exit. Heres a suggestion, Put a cat back and tail pipe on, maybe. lol This will certainly take care of the potential fireball under your car.
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
