383 exhaust
Old Apr 13, 2008 | 09:08 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
383 exhaust
I am trying to find answers for my exhaust. right now I have a 3 inch edelbrock catback. I just bought a set of slp 1 3/4 headers with the y pipe. My idea would be to keep the 3 inch exhaust and put a cut out for when I go racing. I dont have a cat, and hopefully this will flow enough for my engine. Any comments or what works?
Old Apr 13, 2008 | 09:15 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 383 exhaust
single 3inch will choke that motor, but use a good flowing muffler and you will minimize the losses. I'm not sure how good flowing the edelbrock stuff is.
The slp's have a 2.5" collector. You could use a 2 3/4 or 3 inch collector and 2 3/4 or 3inch ypipe too but if you run a cutout in the right spot, probly 2 cutouts, one on each piece of y pipe, you will make up for the losses
Old Apr 13, 2008 | 09:19 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
Which muffler would you recommend for most free flowing. If I put a cut out on each side of the y pipe would that flow enough, and what size cut out would be correct. 2 inch or 2.5
Old Apr 13, 2008 | 09:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: 383 exhaust
Dynomax and Magnaflow make good straight through mufflers. For max power gains from your situation you need to put the cutouts in the right spot. Maybe 18" inches from the collectors.
Old Apr 13, 2008 | 10:46 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 383 exhaust
how high does your 383 rev to? anywhere around 17-19 inches total collector length seems to work well for cars witha peak between 5800-6300 rpms range. thats doable on a y pipe setup
I'm not sure what the y pipe is, proby 2.5 inch but measure it to be sure
I agree, a magnaflow would probly be a good flowing muffler. A good flowing stock style crossflow muffler i'm not sure what would be the best. If you dont mind a single exit, you can run a single UltraFlo or magnaflow Round. else you can have dual exits fabbed up over the rear axle like i did, and run the muffler behind the cat.
Old Apr 14, 2008 | 10:20 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
So I put the cut-outs on the y 17-19 inches from the cut out. I am still looking for a high flow muffler and have come up with these two from summit. Any ideas?
http://store.summitracing.com/partde...5&autoview=sku
Old Apr 14, 2008 | 12:53 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: 383 exhaust
Here ya go man.... I went out and did some research before getting my Magnaflow muffler....I havent heard the Flowtech muffler but it is right there with Magnaflow....but ALOT cheaper....
Also, if you want the Magnaflow muffler DONT get it from Summit unless you want the polished version.....go to your local muffler shop/performance shop and order it there. I paid $90 shipped to my door for the same magnaflow muffler you see in summit but without the polish and for alot less.
anyways here is the dyno that i found on ls1 forum
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
http://www.ls1tech.com/forums/showthread.php?t=113572 try this one too
Last edited by 89formula350b2l; Apr 14, 2008 at 12:55 PM. Reason: Automerged Doublepost
Old Apr 15, 2008 | 10:35 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
what size cutout would be correct for the 2.5 y pipe
Old Apr 15, 2008 | 01:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 383 exhaust
Cutouts are sections of pipe for the exhaust. They come in the same sizes as the pipe.
so if you have a 2.5" pipe, you need the 2.5" pipe cutout
Old Apr 15, 2008 | 02:17 PM
HiTech5's Avatar
Car: 1986 Pontiac TA
Engine: 383
Axle/Gears: 3.70
Re: 383 exhaust
Joe - I had a 383 set up pretty similar to yours. My exhaust was Hooker 2210 Super Comps, 3" Y pipe with dual 3" converters into a 4" Mufflex with Flowmaster muffler and single exit.
I was able to get the car down to 11.61@118 mph with that exhaust right off the street. The motor made peak power at 6500 on the dyno.
Old Apr 15, 2008 | 03:22 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
I just bought some 1 3/4 shorties and i really wanted to use them along with the y pipe and my 3 inch catback. Wondering if I use this setup with you 2 2.5 cutouts 18 inches from the collector, would that flow enough. I don't have a cat.
Old Apr 15, 2008 | 04:16 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: 383 exhaust
Joe, I know you said you dont have cats, but did you get the dual cat y pipe?
Old Apr 15, 2008 | 04:26 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
nope
Old Apr 15, 2008 | 04:28 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 383 exhaust
the cutouts will definately flow enough..its an open pipe at that point
Old Apr 15, 2008 | 04:40 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: 383 exhaust
I'm going the same route Joe....hopefully we will have matching times
Old Apr 15, 2008 | 05:38 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
Sounds good, how far you going to put the cutouts on the y-pipe?
Old Apr 15, 2008 | 06:35 PM
Car: 92 Camaro
Axle/Gears: S60 373
Re: 383 exhaust
around 18 inches give or take an inch....but i HAVE to run cats.....or at least have the shells
Old Apr 17, 2008 | 09:16 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
Anybody ever tried making a 3 inch y-pipe without have clearance issues around the oil pan.
Old Apr 17, 2008 | 01:11 PM
Car: 1989 GTA
Engine: 369 TPI
Re: 383 exhaust
Yes, we have looked into it and there are clearance problems without the pipe hanging low. You can either modify your oil pan (I did) or get a tubular K-member.
Old Aug 25, 2008 | 06:39 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
Would there be any difference in performance with a 3 inch catback with a 3 inch cutout after the y pipe, as compared to a 3.5 mufflex with a ultra flow muffler and no cutout?
Old Aug 3, 2011 | 09:19 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: 383 exhaust
just wondering what HP and ET gains I would get from going with a Cut Out. My exhaust is SLP 1 3/4" into a 2 1/2" Y pipe into 3" Banks-no cats... I know the 3" prob is choking my 385 cu. in. but I dont plan on changing it out anytime soon... So I was thinking of seeing if I'll get any gains with a cut out install under the passenger seat....mods in sig.
Old Aug 4, 2011 | 12:35 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Re: 383 exhaust
I have my 3.5 inch cutout right after the y pipe. When I leave it on I can only go as fast as 12.20 in the 1/4. With the cutout off, I have ran as fast as a 11.64 in the 1/4. So I know that my 3 inch catback is a huge restriction
Old Aug 5, 2011 | 06:16 AM
Car: 89 Formula 350
Re: 383 exhaust
Ok, just ordered 3" electric cut out. I'll post dyno results with it open and closed in the next few weeks.
customblackbird
Oct 1, 2015 04:30 PM
ericjon262
Sep 11, 2015 06:07 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
