What do you think?
Old Aug 15, 2011 | 06:42 PM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
What do you think?
I plan on going with hooker or hedman long tube headers and putting these on them.
http://www.jegs.com/i/Dynomax/289/24...oductId=744702
Do you think there would be any clearance issues?
I don't have to worry about emmisions or inspection because of antique plates.
Old Aug 15, 2011 | 06:47 PM
sailtexas186548's Avatar
Car: 1991 z28
Engine: Turbo 310
Axle/Gears: D44
Re: What do you think?
not going to work with the hedmans, and probably not with the hookers either. It's a pain in the butt to get the pipes out of the trans tunnel and past the cross member when using long tubes
