Headers: Holley paint vs. VHT coating?
Old Aug 15, 2011 | 09:22 PM
Austin19's Avatar
Car: 1985 Camaro Z28
Engine: 305 LG4
Axle/Gears: 3.08
I can't find much info about the stock paint that comes on painted Holly Super Comp headers. Im wondering if the VHT flameproof coating is better than the black paint that comes on the Hooker Headers?
I will be getting the Hooker 2055HKR headers from summit sometime very soon, and I'm just wondering if the time that it takes to put on and bake the VHT coating is worth it compared to the off the shelf hooker paint.
Any info is great
Old Aug 15, 2011 | 09:37 PM
blackbmagic's Avatar
Car: 1985 IROC-Z
Engine: 355
Axle/Gears: 3.42 10 Bolt Posi
Re: Headers: Holley paint vs. VHT coating?
Jet-hot. Period.
Old Aug 15, 2011 | 09:39 PM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Originally Posted by blackbmagic
Jet-hot. Period.
I can't find jet-hot in a spray can, and my air compressor can't handle a gun. Is jet-hot available in a spray?
Old Aug 15, 2011 | 09:42 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
You can send your headers to jet-hot to have them coat them for you. I used the VHT paint on my headers and after curing them, it has held up very well (2 yrs).
Old Aug 15, 2011 | 11:41 PM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
I would love to do that, however I don't think that would be cost effective since I'm in Canada. Did you cure them on the car or in an oven?
Old Aug 16, 2011 | 05:00 AM
EvilCartman's Avatar
Car: '82 Z28
Any paint that comes on headers, unless otherwise noted, is just shipping paint and not high-temp paint. It'll wipe off with lacquer thinner.
Old Aug 16, 2011 | 07:49 AM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
I just stripped the paint off of mine and then cured them in an oven. There are instructions on the back of the can to tell you how to do it.
Old Aug 16, 2011 | 09:04 AM
Car: 1985 IROC-Z
Engine: 355
Eh I wrote a hole lot about vht header paint somewhere, Followed the instructions to the Tee. Gave the headers several coats, allowed them to bake in different temperatures and cure/cool. I was such a believer, but then my carb went lean as I was adjusting timing and the headers heated the nice coating started to smoke right off.
I assume on a stock vehicle, headers would not see the temps that something with a big cam/head-work would so it might be fine. I don't recommend it for anyone with a built motor, that goes through lots of tuning 90% of the time it will burn right off.
Jet-hot is the way to go, do it right the first time and the only time.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Stryker412
Sep 7, 2015 09:11 AM
TheExaminer
Sep 6, 2015 11:40 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
