MAFsensor maintenance?
Car: 1986 Camaro IROC-Z
Engine: 350 swap
Transmission: manual
Any suggestion on MAF Ssensor maintenance?
Can it be done? If so, what's the best way to do it?
Thanks in advanced!
Thanks in advanced!
Engine: 4++,350 & 305 CIs
Re: MAFsensor maintenance?
Maybe post this in TPI section or in General engine tech..
Just spray the wire with electrical parts cleaner..
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Wrong section
You can use an aerosol MAF cleaner- about the only option for a card style, or what I've done with the GM 3 wire MAFs is use a MAF cleaner, and GENTLY followed up with Q tips soaked in alcohol. Be VERY VERY careful with the qtips- you can hook a wire and rip it.
The MAF burn off wont burn off all the K&N air filter oil, plus it dosent burnoff every time you shut off your car, sooo it does get dirty.
The sensor does need cleaned with a cleaner once in awhile.
DO NOT over oil your K&N filters.
I wouldnt touch the wire with a Qtip tho!!!!
Car: 86 Z28
Engine: Built 312
You have a very good question.. I use carb cleaner to remove the oil then the electronic parts cleaner. The burnoff will burn that stuff off.. I do know guys that use Qtips buuuut eehh I wouldn't.. maybe Im to shakey or drink to much but I wouldnt do it.. lol
Car: 86 Z28
Engine: Built 312
BADNBLK
Convertibles
65
Feb 10, 2016 03:36 PM
sjorgens
Oct 1, 2015 07:54 PM
