corrosion on header why and how to remove??
Old Sep 29, 2011 | 09:01 PM
Phx89Iroc's Avatar
Car: 1989 IrocZ Convertable
Engine: 350 5.7
Transmission: AUTO 4 SPD, THM 700 R4
Axle/Gears: AXLE REAR, 2.73 RATIO
this is a header on a car i just purchased, and im trying to figure out what caused this and how i can clean it headers are supposed to be only < 2 yrs old. the corrosion almost looks like water calcium deposits and its only on the one side of the car. i tried vinegar rubbing with brillo pad but it didn't really help much.
i was told these were titanium coated headers but does that look ceramic?
Old Sep 29, 2011 | 09:03 PM
torque_is_good's Avatar
Re: corrosion on header why and how to remove??
honestly, I wouldn't even concern myself.
Old Sep 29, 2011 | 09:10 PM
Phx89Iroc's Avatar
Engine: 350 5.7
i have the engine out and apart, am painting the block and trying to make it look nice and clean before i put it back in. i don't know enough about headers to know what caused this, mostly curiosity factor. it was an az car so not exposed to rain.
Old Sep 29, 2011 | 10:04 PM
Phx89Iroc's Avatar
Engine: 350 5.7
i found out it is dried up fire extinguisher spray from a small fire on the first car they were on.
Old Sep 30, 2011 | 08:00 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
If you are really worried wire wheel on a drill or a sand blaster then paint with header paint.
Infested
May 22, 2018 11:56 PM
hectre13
Sep 8, 2015 03:38 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
