Y Pipe Gasket Question - 92 RS
Old Oct 5, 2011 | 10:21 AM
LarryD's Avatar
Car: 92 RS
Engine: 3.1 V6
Can anybody tell me the correct gasket configuration for both the drivers side and passengers side Y Pipe to Manifold connection... I bought two donut gaskets but then realized when I took the old pipe off last night that there is a steel ring that fell out of the drivers side that is like a donut gasket except it is flat on one side and shaped like a donut gasket on the other side.. Was wondering if anybody has an assembly picture of the correct stock setup for gaskets and whatever between the Y Pipe and the manifold on each side... Should there be a steel ring on both sides? Does that replace the traditional donut gasket? Parts houses don't seem to really know.... Thanks...
Old Jan 20, 2013 | 12:26 PM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
Re: Y Pipe Gasket Question - 92 RS
Anyone? im wondering the same thing. i have a donut on the passenger side, and no gasket on the driver side. There is a rattling / ticking exhaust leak which was improved greatly by tightening the bolts near the exhaust manifold on the driver side.
Old Jan 20, 2013 | 01:49 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
No gaskets. Flange pulls the flare on the pipe tight onto the taper of the exhaust manifold.
Old Jan 21, 2013 | 09:34 AM
FreeSpirit's Avatar
Car: 92 RS
Engine: 305 TBI
The flange is the donut shape right? I have one on the passenger side but not driver. Im supposed to have both right?
Old Jan 21, 2013 | 01:54 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
On the driver side, there is no donut gasket. The outlet of the manifold is tapered inward and the y-pipe connection is flared outward. The bolting flange around the pipe (the thing the 2 studs go through and you tighten the nuts against) also has a matching taper that compresses the pipe and manifold together.
The passenger side has a few different configurations, depending on your application. The bare manifold outlet should be flat with a bevel machined into the I.D. of the oulet hole. From there, I know of 3 different options. Option #1 is a double tapered donut gasket between the manifold inner bevel and the y-pipe flare. Option #2 is a cast iron spacer that is flat on the manifold side and tapered on the pipe side. Option #3 is similar to the spacer, but it is a vacuum operated butterfly valve (used for some carburated applications). Options 2 and 3 from the factory did not have any gaskets on the flat machined surfaces between the manifold and the spacer/butterfly valve, however this connection will leak if taken apart and put back together without a gasket. It's been a while, but I don't remember there being a gasket available, however I was able to match one up at the parts store.
Since there are no donut gaskets on these cars, the manifold to y-pipe connections are very difficult to assemble without leaking. Take you time, get both sides lined up and centered and tighten all 4 nuts evenly. If they still leak, loosen the nuts, reposition the y-pipe and try again.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
hectre13
Sep 8, 2015 03:38 PM
NinjaNife
Aug 23, 2015 11:49 AM
redmaroz
Aug 16, 2015 11:40 PM
