exhaust insulation [not header wrap]
Old Dec 18, 2011 | 09:53 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I know about header wrap but some reason Im having a hard time searching for what I want.
Maybe I need a tip on a search term?
Looking for what I know I have seen before, a big section of yellow insulation with an aluminum cover you can wrap a bullet type muffler with.
Hate to say very similar you see in a hardware store but Im sure much more fire proof. [house insulation will burn]
I run my bullet right off the engine, so it right under the floor.
[got header wrap on section of pipe before it.]
wanna ask for some for xmas
Old Dec 18, 2011 | 10:08 AM
OdieTurbo's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 3.4L V6
Transmission: T5 (NWC)
Axle/Gears: 3.42 Stock axle
Re: exhaust insulation [not header wrap]
These guys have lots of products.
http://www.heatshieldproducts.com/productdetail/heat-shield-and-thermal-barriers/thermaflect-heat-shield/50/21
Old Dec 18, 2011 | 10:43 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That stuff and ones similar on ebay sort of tip toe around that its not for direct contact with the muffler system.
like it would go on the floor above it, not wrapped tight around the muffler.
Old Dec 18, 2011 | 10:45 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
That stuff and ones similar on ebay sort of tip toe around that its not for direct contact with the muffler system. Those are just shields.
like it would go on the floor above it, not wrapped tight around directly on the muffler.
Old Dec 18, 2011 | 12:36 PM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Look for downpipe universal insulation, turbo cars use what you're referring to most of the time. Direct contact with the downpipe. Or in your case, the muffler.
Old Dec 18, 2011 | 04:49 PM
3rd Coast Z's Avatar
Car: 1987 IROC Z / 1999 Suburban 2WD
Engine: Lingenfelter 383 / Vortec 350
Transmission: 700R4 / Built 4L65E
Axle/Gears: Stock / 4.56 Locker
http://www.heatshieldproducts.com/pr...eld-kit/103/33
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
89fast5oh
Sep 8, 2015 09:55 AM
Accerrito22
Sep 5, 2015 09:34 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
