Y-pipe 5.0 versus 5.7 V8
Old Dec 26, 2011 | 04:30 AM
Fire"Dutch"Bird's Avatar
Car: '88 Firebird Formula 350
Engine: 350 (5.7 TPI)
Transmission: auto 700R4
Axle/Gears: BW 9-bolt L.S.
Are they the same?
Y pipe for '88 5.0 V-8 and '88 5,7 V-8?
Thanks.
Old Dec 28, 2011 | 06:38 PM
HotRodkid87's Avatar
Car: 87 iroc-z, 89 dakota sport
Engine: 305 ci
Axle/Gears: 3:27
Re: Y-pipe 5.0 versus 5.7 V8
yes they are ezactly the same. The 305 and 350 are really identical. the only real difference is 3.75" pistion in the 305 and 4.00" in the 350.
Old Dec 29, 2011 | 06:57 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Different.
From TransamGTA350:
There were only 2 different manifolds for the V8's throughout the years, but they were different depending on what motor and gearing package they came on. Here is the breakdown.
2" outlet manifolds with single 2 1/4" y-pipe
82-87 305 LG4 (VIN H)
88-92 305 L03 (VIN E)
82-83 305 Crossfire
90-92 305 LB9 w/o G92 axle (VIN F)
2 1/4" outlet manifolds with single 3" y-pipe
83-86 305 L69 (VIN G)
85-89 305 LB9 (VIN F)
88 350 L98 (VIN 8)
89 350 L98 w/o G92 axle (VIN 8)
2 1/4" outlet manifolds with dual 2 1/4" cats
89 350 L98 w/G92 axle (VIN 8)
90-92 350 L98 (VIN 8)
89 305 LB9 w/G92 Axle (VIN F)
90-92 305 LB9 w/G92 (Vin F)
The manifolds from the single 3" cat and the dual 2.25" cats are interchangeable. On the passenger side manifold, some will have the heat riser butterfly valve, some will have a spacer, and some will just have a donut gasket. You most likely have the wrong manifold for your application. If you have the larger manifolds, then it may be worth it to get the larger y-pipe for some more performance.
JamesC
Old Dec 29, 2011 | 02:14 PM
I can get a new Y-pipe for the 5,0 V-8 overhere, but it doesn't say if it will fit the 5,7 V-8 that I own....
They look the same, but it doesn't fit according to the post directly above?
Old Dec 29, 2011 | 02:32 PM
JamesC's Avatar
Check post #7 in the link below for a comparison pic between an LG4 (2" outlet / 2 1/4" Y) and an L69 and/or an L98 (2 1/4" outlet / 3" Y). A 305 could scarcely breathe with the LG4 version little lone a 350.
https://www.thirdgen.org/forums/exha...-question.html
JamesC
Last edited by JamesC; Dec 29, 2011 at 03:07 PM. Reason: Neglected to Post the Link
Old Dec 29, 2011 | 03:18 PM
Thanks for the info.
KO1
16
Oct 15, 2015 05:00 PM
LT1Formula
Oct 8, 2015 08:34 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
