Does this sound like too much?
Old Dec 26, 2011 | 05:54 PM
ironreaper87's Avatar
Car: 1987 IROC Z28 Camaro
Engine: HSR L98
Axle/Gears: stock
I am installing true duals in my IROC follow stock routing.
Reason why is because I need as much ground clearance as possible.
And so far..the clearance is better then stock believe it or not...I will try to get pics.
but everything including mufflers, reducers, ceramic hooker headers (I am doing the labor) is coming out around $900.
I had to buy pre bent piece because I do not own a mandrel nor does anyone within an a 2 hour drive around me :/.
Old Dec 26, 2011 | 06:16 PM
Steve Mack's Avatar
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
Re: Does this sound like too much?
You need to talk to Dyno Don on your choice of exhaust he sells a killer setup.Read some of the posts in this Exhaust section.For the amount of money you want to spend you would get a direct fit and more horsepower.
Old Dec 26, 2011 | 10:04 PM
Engine: HSR L98
Axle/Gears: stock
Whew. Its been 4 hours and I've done a ton of mock up with the tubes. Every thing is working perfectly. Still have to start on the headers though.
Im running 2.5 inch all around now im just waiting for my reducers to come and a few extra tubes and I will be able to post on here.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
wanext
Oct 6, 2015 12:18 AM
Fanatic1074
Oct 2, 2015 03:47 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
