headers install with engine out
Old Jan 17, 2012 | 04:42 PM
trafficlightguy's Avatar
Car: 1988 iroc
Engine: 350 30 over
Axle/Gears: Series 2 373
what type can be installed on the engine out of the car and droped in the engine compartment with very little problems,
looking to do a true dual exhaust
thanks
chris
Old Jan 27, 2012 | 09:24 AM
Seven_MPG's Avatar
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Re: headers install with engine out
None.You could do it with stock manifolds but not headers.See the stickies at the top of the exhaust forum.
Old Jan 27, 2012 | 03:16 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
It can be done but not with long tubes. I did it with SLP's with no problem. It's the best way to do it because you can get the bolt tight. Do it with the intake on as well. Oh yea, I also did with the hood on, the radiator and fans still in place.
Old Jan 27, 2012 | 03:56 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
I've always laid my SLP drivers side header in place before dropping in the engines. I would think the passenger side wouldn't be to bad but I've always had clearance issues with the drivers side header and steering column. How did you clear the column with the headers on the engine?
I've also put a few engines in with the intake on with no issues.
Old Jan 27, 2012 | 04:05 PM
Ronnie Brennan's Avatar
Car: 1986 Camaro
Engine: 355 N/A mind 400hp build
I have edelbrock shorties and passenger side comes out/in like a dream. Drivers side requires a bit of finesse to get in but its doable when I put my new motor in the car I'll probably place the exhaust in or bolt it on the drivers side.
Old Jan 27, 2012 | 04:12 PM
VincentZ28's Avatar
Well first I do have poly motor mounts. The engine sits up 1/4in higher. Even though the motor mounts looks the same, there not the same. If you swap them to the opposite side, it moves the engine over about 1/4 inches. That's why my SLP's clears the steering shaft 1/4 inches.
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
drathaar907
Aug 6, 2015 04:20 PM
