Borla cat back install
Old Feb 14, 2012 | 09:15 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I got a full cat hack borla for 75 bucks off of craiglist the only problem is that it is completely welded together how would I get it over the rear end without cutting it all up into pieces ???
Old Feb 14, 2012 | 10:15 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: Borla cat back install
Jack the car up high. Pull the driveshaft. Disconnect the torque arm. Disconnect the PHB. Lower the rear axle down by disconnecting the shocks, let it swing down hanging from the LCAs. Slide the cat back forward from the rear, slipping the intermediate pipe over the axle until it gets where it is supposed to be.
Old Feb 15, 2012 | 07:52 PM
Engine: LR4 4.8
Do I have to worry about the springs flying out also what should I replace when I have rear end down on the jack pretty much doing a complete overhaul on the is car somewhat
Old Feb 15, 2012 | 08:00 PM
HeavyThundar's Avatar
Car: 81' Z28, 87' Iroc Z28, 05' GMC Z71
Engine: LB9 - 305 TPI - 190 H.P.
Axle/Gears: G92 - 3.23
Fuel pump, universal joints, shocks, rubber brake line running from chassis to rear axle, brake pads/shoes/hardware, springs, the rubber pads the springs sit on if they're in bad shape, pan-hard bar/bushings, lower control arms/bushings, torque arm mount rubber isolator.
Old Feb 15, 2012 | 08:41 PM
Car: GTA
The rear springs won't "fly out". With the rear axle at full droop even with the shocks still connected, the springs will either barely be in there & could be pulled out or will fall out. So I wouldn't really have your head directly under them, just in case.
All the stuff that Heavy Thunder mentioned is stuff you can look at while your under there, but none of it is "required" to do while your there. But if any of it is "bad", you might as well replace it while your under there, if your wallet allows it.
Old Feb 15, 2012 | 09:56 PM
Agreed. Didn't mean to come off as "YOU HAVE TO REPLACE THESE ITEMS" if i did lol, that would be a big stink if you did. lol
Old Feb 17, 2012 | 07:57 AM
Engine: LR4 4.8
Yea that's true I found that the borla wasn't welded together it is clamped right at the bend going over the rear end so looks like just the phb an track bar will have to come outta the way the exhaust on the car now is a 2-1/2 inch with no cat the borla is a 3 inch so looks like I gotta put a adpater to actually bolt it up errr an clamp it all down then drive it over when it's on the road to get welded shut
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
drathaar907
Aug 6, 2015 04:20 PM
