Borla adaptor plates
Old Feb 17, 2012 | 09:21 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Ok so I finally got the borla installed on my 88 Gta but It kinda sounds like poop at the moment I seen that the exhaust cat back system is suppose to come with adapter plates to flow the exhaust through the muffler instead of making it come out the exhaust cut out. Now I got this exhaust off a craiglist seller an I did not get the adpator plates with it. Where can I get these adpator plates or could I make my own outta thick sheet metal with different size holes in each plate ??? Just a thought
Old Feb 23, 2012 | 03:53 PM
Scamo-2.8's Avatar
Car: 1989 Camaro RS
Engine: 1990 - 5.7
Transmission: Tremec 3550
Axle/Gears: 9 Bolt - 3:45
Re: Borla adaptor plates
I got mine from Borla themselves. Just give them a call
Old Feb 23, 2012 | 05:03 PM
Engine: LR4 4.8
I made my own just used old sheet metal laying around the canopy an made a couple of holes for the bolts an different holes to flow the exhaust thanks for the help though
Old Feb 25, 2012 | 08:45 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I had some CNC'd out of 1/8" alum.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
