Long tube header problems
Old Mar 2, 2012 | 04:43 PM
Demonic13's Avatar
Car: 1991 Chevrolet Camaro 25th Anniv.
Engine: 5.7L 350 TPI
I will be running long tube headers. I am just a little worried about these possible issues or any other that you inform me about. Has anyone run into problems other then clearance? For example:
1. The O2 sensor not reading right causing the engine to not run right?
2. To much exhaust flow, not enough air flow or vise versa?
3. Reaching a certain MPH or RPM and the motor choking or Making RPM bounce or Making a noise?
4. In proper exhaust flow or check engine codes?
5. What other problems have you encountered?
Please let me know and make me aware of what I will need to do. I am only focused on the header issues for now. Thank you.
Old Mar 2, 2012 | 04:48 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: Long tube header problems
you might have to run a heated 02 sensor. i dont see the engine choking at all. i have shorties on an rs with a 305, high flow cat, and a magnaflow catback and i didnt loose power. choking. i doubt it.
Old Mar 2, 2012 | 04:54 PM
Demonic13's Avatar
You think the results will be the same on the Long tubes? Thanks.
Old Mar 2, 2012 | 06:12 PM
one92rs's Avatar
Car: SOLD!!!!!
they will work good.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
beast94
Aug 20, 2015 06:44 AM
