Fitting Flowmaster Exhaust to Magnaflow Cat
Subscribe
Mar 5, 2012 | 10:59 PM
I just bought the Flowmaster 17234 Cat-back system and need to find a catalytic converter that will fit it. The Flowmaster says it is for a 2.5" flanged cat. Will the Magnaflow 93456 Cat Converter fit onto the Flowmaster? It says it is a 2.5" stock flange. I assume it will but need some reassurance. Here's the links to what I'm talking about. Thanks for the help!
Cat:
http://www.summitracing.com/parts/MPE-93456/
Cat Back:
http://www.jegs.com/i/Flowmaster/389/17234/10002/-1
My Y-Pipe is 2.5" inches and the Magnaflow cat says the inlet is 2.25", I assume the exhaust shop can just reduce that part??
Reply 0
Mar 6, 2012 | 07:31 PM
Re: Fitting Flowmaster Exhaust to Magnaflow Cat
Anybody?
Reply 0
Mar 6, 2012 | 08:17 PM
Thats exactly what I'm running. I have that CAT (93456) coming off of a stock Y pipe then that CAT entering the American Thunder Flowmaster CAT back.(17234) Talk to the Summit Tech about your set up and get a final clarification at 1-330-630-0240
If I remember correctly the cat slides in to the Y pipe.Thats why there is a difference in size/diameter. The cat is a direct/exact replacement for the stock one.Other than that the quality and composition and higher flow capabilities of the Magnaflow are what makes it different/better.
Reply 0
Mar 6, 2012 | 11:55 PM
Awesome. Thanks for the info!
Reply 0
Subscribe
