I want to coat my own headers...what do I need?
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Hey guys
Once again i'm in DIY land and I want to start coating my own headers. What do you guys think I need to get started? What tools work best and which company provides the best DIY coating? Any help would be more than awesome.
Engine: 4++,350 & 305 CIs
Re: I want to coat my own headers...what do I need?
Eastwood has some decent stuff. Most home "jet hot" kits dont work very well but that eastwood manifold coating works fairly well..
Car: 82 Trans Am
Engine: 13:1 383 stroker on e85
Transmission: t-56
Axle/Gears: ford 9" locker 3.70
I have some left over "ceramic" from several projects. I purchased my materials from columbia coatings.
I have a 2/3 full 8oz bottle that msrps for 35.95 will sell for $25 shipped, and a full never opened 20oz available as well. msrp 83.99, both are the "polished silver"
as seen here: http://www.columbiacoatings.com/category_s/1052.htm
pm me if interested
pm me if interested
how does the coating hold up? if it works well I'm interested. Also, what other tools might I need for a "professional" outcome. I know I need a sandblaster but luckily I have a friend that works at Laron industries who can hook me up with that for free.
Car: 82 Trans Am
Transmission: t-56
The coating is great, its not really a DIY grade or anything, this place just sells to pro's and the casual buyer. After blasting its important not to touch the bare metal at all with your skin, I used latex gloves to handle metal after. Simply spray on light even passes until covered, one coat is all you do. let dry over night, cures on car.
you apply this with a spray gun like this: http://www.harborfreight.com/air-tools/paint.html
Sweet, how do I spray the inside of the headers? Which one of those spray guns would work the best?
Car: 82 Trans Am
Transmission: t-56
I never sprayed the insides more than what I could from the ends. It's really not needed
Car: 87' IROC
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I just coated my shorties with "techline's" satin black(BHK)......sandblasted with a harbor freight portable sandblaster, then cleaned with marine clean, then used metal prep and painted with a harbor freight HVLP touch up gun with a 1mm tip....came out great
How have they held up so far? plus I have another question. Has anybody heard of cerakote coatings? There is a place here in town that I found that uses there product for ceramic coating. Any thoughts?
Car: CTSV
Engine: LS6
Techline seems to be getting popular and I have heard it holds up well. I have specifically seen one account of the headers themselves 100 degrees cooler. Outside coat only. Eastwood makes and inside coat system for cheap.
Car: 85 Z28
Engine: GMPP 350 HSR
Axle/Gears: 4th gen 3.42 Posi LS1
Cerakote is just another name for a ceramic coating made by NIC Industries. That is I believe the same coating columbia coatings sells. It is a very good product. I use NIC and columbia for all my powder coating supplies I use. Keep in mind NIC has 2 versions of the cerakote 1 specific for firearms. I don't know if there is an actual difference though.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Only as good as the surface prep.
Sandblast the headers to clean bare steel, wipe with a oil grease remover, and a final wipe.
Hotrodboba400
Dec 10, 2019 07:07 PM
redformula88
Oct 14, 2015 06:08 PM
