How to knock off rust from headers?
Old May 13, 2012 | 12:30 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I picked up a set of long tube headers for my engine build and they have surface rust on then from sitting, I used steel wool to remove the rough stuff from one of them but the wool degrades and wears away really fast, any other tips?
Old May 13, 2012 | 12:45 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: How to knock off rust from headers?
wire wheel on a drill, scotchbrite , sand blast.
Old May 14, 2012 | 07:15 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
ditto. been doing it this way myself forever (wire wheel and drill). if this doesn't get rid of it, you've got bigger issues
Old May 20, 2012 | 09:30 PM
dacuma's Avatar
Car: 89 Irocz
Axle/Gears: 342
Yeah sandblasting would be the way to go. You should get them coated also, cause if the rust is brothering you now, your going to be really ticked once you see them on your engine for a month and the rust comes back. Plus it will look sharp and help keep the engine temps down and protect the headers. And if you do get them coated, they have to clean up the headers to coated them. So a win,win for you.
Hotrodboba400
Dec 10, 2019 07:07 PM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
