removing catalytic converter
Car: 1984 camaro z28
Engine: L69 H.O
taking off the catalytic convert any tips. i know u have to take off the 4 bolts on either side but are there any tips or tricks to get them out. i dont have emissions and dont care how it sounds i just want it off
Car: 1984 T/A WS6
Engine: L69 305
Axle/Gears: fact G80 with GT4 3.73
Re: removing catalytic converter
this should be good. be nice Kid and Kevin.
as far as taking it off. its just like u said. unbolt it wrestle with it alittle and it should come off. and if that don't work take a saw to it. u might have to cut the air tube goin from the motor to the cat. if u are replacing it with a mac off road pipe then just get an air tube repair kit at autozone. if u are removing the air pump and all the other *****,then just remove the air along with it.
Engine: L69 H.O
Alright so i have been trying for 2 days to get these bolts loose i have coated them with a whole can of wd40 and another can of penetrating oil but they still wont budge Any ideas?
Car: 1984 T/A WS6
Engine: L69 305
cut them off and get new hardware. or take an air ratchet to them. i just cut mine off b/c the only thing i was goin to saved was my cat and fact l69 y-pipe. now they are both collecting dust.
Engine: L69 H.O
I just decided to hollow it out. Those bolts were on there really good im kinda strong for a 16 year old and it took everything i had to break them loose only one of the bolt heads snapped off. It runs a whole lot better and the exhaust is a little louder thanks for your help.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
This topic is one of the most popular on this board.2. Yes you do have emissions, just like every other thirdgen that was sold in the United States. Every car that is driven on the street is required to have the emissions devices it came with, or be replaced with 50-state legal parts. Just because your area doesnt do emissions tests does NOT mean you are free to remove what you want and let the people behind you breathe your bad exhaust.
3. Please replace your gutted cat with a good aftermarket "high-flow" cat such as Magnaflow as soon as you can. Our status as responsible hot rodders depends on it.
Car: 1989 CAMARO IROCZ Z/28
ay i see you live in e-town. i live in st matthews. nice third gen real clean, alot nicer then mine whose struggling with paint
Car: 1987 T/A WS6 T-Tops/92 RS
Engine: LB9/3.1
Transmission: 700R4/700R4
Axle/Gears: 2.73/3.23
1.
This dude must work for the EPA LOL!
1992 Trans Am
May 10, 2023 07:19 PM
