Where is proper place for exhaust cut-out
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Re: Where is proper place for exhaust cut-out
I have been racing seriously since the early 90's then it was Top Alcohol Funnycar and ProMod. Moved into the world of Outlaw Street in the late 90's. Where THE RULES called for full exhaust beyond the drivers seat. These are cars that at the time were running low 8's in the 1/4. now its mid 7's.......................on 10.5" tires..........
So dont tell me about the race track and mufflers son.....
You just dont know what fast is all about.................When a street leagal car is putting down numbers that promods are impressed by.................you tell me
If you dropped 5/10's with a cut out that tells me whats behind the cut out is junk.
Install a properly sized low resrtiction system with a non-crossflow muffler and see 3/10's ontop of that 5/10's......
Anyway, to stay on topic, how do you like your cutout Buggy? I finished mine up today, and I love it. Here are a few pics.
I cut off the ball flange from the cat converter, no point buying a new one when I can reuse the hanger too.
Here is the extension I made to make up for the difference from the cat converter compared to the cutout.
Here it is finished. So far it fits perfect, no exhaust leaks, and the cutout being open or closed makes a world of difference as far as sound goes. I'm not too worried about the cutout leaking, as I'm guessing that's from where the cutout clamps onto the exhaust, not where the cover is. I cut off the inner lip on both sides and just welded 3" pipe flush with it, so no leaks there. Overall I'm very satisfied with my cutout. Taking off the cover takes literally less than 60 seconds.
Car: 1992 Camaro RS
Engine: 3.1
Transmission: 5 Speed
Axle/Gears: 3:42
Very nice looking mod. I would like to do the same sometime with the cat as I have to have it. Does anyone know if this will be a cause for failure of the Virginia State inspection for having the cutout.
Engine: 385
If you can find a place to put the cutout before the cat, you should be alright. It just acts like a pipe when the cover is on, directing exhaust through the cat. It's very hard to put the cutout before the cat in the stock location though, and even if you can, it's really hard to get to. I would suggest moving your cat about 2 feet back from it's stock location, and just put the cutout where the cat was.
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
hey man, watch out if by some chance you have to return it.. i had to return mine and they chard a 20% restocking fee and they send you a check back in the mail......never got my check and its been 3 months. had to call the credit card company. i wont ever do business with them again. word to the wise
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
How loud is your cutout out with no cat?
Engine: 385
Closed it sounds about normal, same volume, just a different tone from the headers. Open, it sounds like open headers on a race car. Not quite the same, as I have the stock cam, and a racing cam would make it sound a lot more choppy. Definitely enough to not run stock at the track with it open though
Car: 1991 Camaro Z28
In my case I'm returning the Summit brand cutout so Summit is giving me a credit towards the QTP. SO I'm laying out the $50 difference. I have heard that the QTP is a much higher quality product then the Summit brand. Anyway being I'm orderering the QTP through Summit I'm sure they would be better, they always take my returns. Sounds like your ordered through QTP direct?
Car: 89 Formula 350
mines under the passenger seat where the cat was
Axle/Gears: 4.10
well that would explain why it isnt as loud as you thought it would be..
Axle/Gears: 4.10
Yeahp. The guy said my exhaust was real thin, and I will need a catback soon. I figured thats when I get new headers, than have the cutout before the cat, then have the magnaflow muffler. Im hoping the new magnaflow will sound like the way my cutout sounds, then my cutout will be loud.
Engine: 385
well if your putting your cutout then before the cat...it wont matter about a muffler... the exhaust is leaving the pipes way before it reaches the muffler. and magnaflow isnt that loud until you get on it. at idle its pretty quiet. a muffler wont even sound like a cutout either, especially if your running it with headers before the cat.
As far as a muffler goes, you can have a loud car with a muffler on it. I'm at the track 3 nights a week, and there are quite a few 4th gen guys that run stock class but they definitely don't sound like it. I asked them about it, and they run headers back to a muffler. No cat, but the muffler is pretty much an open pipe with a spiral in it. You can't really tell until they really get on the gas, but at WOT they are loud! You could probably get away with something like that on the street, just like on the track, for the sole reason that it is considered a muffler.
I think what he wants is to put the cutout before the cat, and get a muffler that sounds like the cutout does now (after the cat), and for his cutout to be louder, since it will be before the cat once he gets a new cat-back system.
Engine: 385
Axle/Gears: 4.10
And I know a muffler cant make the same sound as an open header does. Especially if it's cammed.
Car: 1992 Camaro RS
Engine: ZZ4 Crate Engine (350ci)
Transmission: 5 speed manual
Axle/Gears: Richmond 3:73
Personally I'd get headers and a full exhaust. But if that's not in your budget then I'd say ditch the cat all together (if you don't have emissions testing in your state) and put it there... it won't be that much louder when it's closed just because the cat is gone. Also, if you're only planning on leaving it open for short periods of time (like one run down the strip) then it's fine to just run it out right under the car. If you're planning on leaving it open for extended periods of time I'd run a pipe so it goes out the side of the car... like behind the front tire.
Get electric for sure, it's worth the money... if your at a light and a mustang pulls up and wants to race you gotta be able to open it up on the spot.
And regarding the talk about whether it will add power or not... of course it will. Anytime you reduce back pressure you're adding power. How many car shows have you seen where they add a 'cat back' exhaust system (with mufflers), throw it on the dyno, and pick up 10hp or so (give or take depending on the car and what else has been done). Of course it will add power. And it will be LOUD AS HELL once you break about 3000 RPMs!
Hotrodboba400
Sep 2, 2015 07:28 PM
