Catalytic Converter Orientation (305 VIN Code H)
Old Jul 4, 2012 | 01:50 PM
TA-1984's Avatar
Hi, I have a 1984 Trans Am with a 305 (VIN code H, 4bbl) and am replacing the exhaust system from the Y-pipe back. The car did not have a catalytic converter or an AIR pump installed when I bought it. (I plan to install an AIR pump at some point.) After reviewing the service manual and some other material, I am not sure what is the proper orientation for the cat converter with regard to the AIR tube. Should the AIR tube pick-up be on the upper left or lower right (back looking front) . . . . Not sure the attached photos help, but thanks for any insight.
Attached Thumbnails Catalytic Converter Orientation (305 VIN Code H)-photo.jpg   Catalytic Converter Orientation (305 VIN Code H)-photo-1.jpg
Old Jul 4, 2012 | 02:25 PM
Starfish's Avatar
Car: '90 GTA
Engine: 385 Stroker
Transmission: 700R4/ Edge 3400
Axle/Gears: 10 bolt/ Richmond 3.73
Re: Catalytic Converter Orientation (305 VIN Code H)
I wana say lower left. But it's been a while since I've seen one with the air pump hooked up.
Old Jul 4, 2012 | 04:34 PM
nhgator's Avatar
Car: 1985 T/A
Right side picture is how mine was,facing the inside of the car.
Old Jul 4, 2012 | 08:54 PM
chuco89's Avatar
Car: 1991 Camaro RS
Engine: 305 V8
Axle/Gears: Stock Rear 10 Bolt
is that a direct fit cat? what brand and/or product number is it?
Old Jul 5, 2012 | 09:25 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Tube needs to be back looking front, with the ball & socket flange toward the back of the car.
Is this a 3" cat?
Old Jul 15, 2012 | 10:28 PM
TA-1984's Avatar
Thanks, and I appreciate the advice - I installed it as suggested (facing inside of car).
As for the cat, it's a direct fit (2 1/4") that I bought at NAPA, part number 15735. All parts for the exhaust system (including hangers) fit well, except for the driver's side tail pipe: the section coming out of the muffler was too short (not enough clearance for the trunk well), so I had to take it to a local shop to have an additional 3" welded to it.
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
gta90
Sep 15, 2015 04:00 PM
