Hooker 2055 question
Old Jul 6, 2012 | 09:00 PM
88camarofreak's Avatar
Car: 1988 Iroc z
Engine: LB9 HO
Axle/Gears: 3:08 GU4 GU6 Soon :)
Hi, I just recieved my Hooker 2055 headers im pumped. My question is should I clean up the ports on the primary tubes? I fitted the gaskets on the headers and it seems i could port the tubes for some better flow. I am going to definently going to port the collector flange from 2.1 inch to 2.25 inch or so. Just curious if its worth the effort or if other members have done this before? Thanks
Old Jul 7, 2012 | 07:24 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Hooker 2055 question
Doing a little light grinding on sloppy welds is common. But take too much, you'll have heat cracks in no time. Your main concern is getting a flat mating so the gaskets will seal. The insides of those primaries is larger than the stock port exits of the heads, so no need to try much tapering.
Old Jul 7, 2012 | 10:08 AM
Car: 1988 Iroc z
Engine: LB9 HO
Which port size is correct to mate to my 081 heads (1.55" x 1.63" D port or the square 1.5" D port)? Im either getting Earls or Percy's. Would I be ok if I loctited (low grade strength) the header bolts. Thanks
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
billybob6110
Sep 24, 2016 09:50 AM
formula_novice
Sep 5, 2015 03:58 AM
tricky1
Aug 23, 2015 01:17 PM
redmaroz
Aug 16, 2015 11:40 PM
