4 inch exhaust????
Old Aug 11, 2012 | 09:29 PM
3rdgen82's Avatar
Car: 82 Camaro
Engine: 4 bolt 350 SBC
Transmission: 4 Speed
Axle/Gears: 4:10 Posi
4 inch exhaust????
Do you guys think 4 inch exhaust is too much flow for a basically stock 350? Id like to run dynomax bullets pretty much right after the collectors into 4 inch out the sides in front of the rear tires. There will be an H pipe before the mufflers.
Old Aug 11, 2012 | 09:40 PM
BlackenedBird's Avatar
Car: GTA
Axle/Gears: Aussie 9-bolt/3.27 posi
Re: 4 inch exhaust????
Yes
Old Aug 11, 2012 | 10:08 PM
3rdgen82's Avatar
Car: 82 Camaro
yes what?
Old Aug 11, 2012 | 10:11 PM
Car: GTA
Yes.
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
yes what?
Yes to your question. Even a dual 3" would be too much. Just upgrade to a single 3" and you should be fine for your stock motor.
Old Aug 12, 2012 | 09:39 AM
Untamed Z's Avatar
Originally Posted by BlackenedBird
Yes.
Old Aug 12, 2012 | 10:37 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
yes
a single 3" will cover 95 percent of cars out there
Old Aug 13, 2012 | 09:35 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Yes it will be too large for a stock 350, but if you plan on going with a larger or more powerful engine, it might be a good idea - so you don't replace it twice.
Running pipes out the side is a really bad idea - not enough ground clearance with a 2.5" pipe and with the 4" it would be comical how low it would hang. Everyone I know who did a side exit exhaust ripped it off within a few weeks at best...
Old Aug 15, 2012 | 05:23 PM
5spd-iroc's Avatar
Car: '85 iroc-'13 powerstroke H&S tuned
Engine: 406 sbc full roller
Transmission: t5 soon to be t56
Axle/Gears: stock
yep mine lasted a week, sounded like a harley if you werent directly in front or behind it, to the side with my cam i hated it, switched to hawks 4" sinister and love it, i also have a fairly snorty 406 built up hence the 4"
Hotrodboba400
Dec 10, 2019 07:07 PM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
ericjon262
Sep 11, 2015 06:07 PM
raymondandretti
Exterior Parts for Sale
Sep 6, 2015 12:51 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
