exhaust delima...
Old Aug 12, 2012 | 11:21 AM
TKR 88 GTA's Avatar
Car: 1988 GTA Trans Am
Engine: HSR 350
exhaust delima...
Ok so here's my delima... I want a dual set up but as of right now I got hedmann shorty headers with a crappy y pipe that was fab'd up and a not so great 2.5" exhaust after the y. My problem is now I have afr195's and cam and hsr intake so I need a lot better flowing exhaust than what I got now. So I also have a set of Doug thorley long tube headers that have the 1 3/4 headers, when I tried to put them on the header would hit the knock sensor on the passenger side. When I got the chip for the set up burnt the knock sensor was taken out. I have seen set ups to where the exhaust is ran down the stock location just as dual pipes with an x pipe and still looked clean. But I know I would probly benefit from the 1 3/4 primaries of the longtubes but I have the auto tranny and run into the issue with the cross member clearance. But I've heard that going from 2.5" 3" out y pipe is just as beneficial for what I'm looking for and needing. I also have been told a full 3" exhaust kills my top end I find that hard to believe?
Can anyone clear up what I should do lol I'm kind of a noob to exhaust so any info helps out a lot I would rather get info that I know is true than from the guys around here that haven't really built a car.
Old Aug 13, 2012 | 08:30 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: exhaust delima...
If you do a 3 inch exhaust all the way you should be flowing enough for your motor. Those longtubes would probably be fine if they would fit.
Old Aug 13, 2012 | 09:06 AM
TKR 88 GTA's Avatar
Engine: HSR 350
So do you mean 3" all the way back as in duals or a 3" from headers to a y pipe then 3" all the back. And that shouldn't kill any top end performance right? I should gain quite a bit.
Old Aug 13, 2012 | 09:21 AM
Guest
Guest
Posts: n/a
Will you hit 180mph? No. Will you lose top end? No. Here's the set up you want to go with: 1 3/4" headers (long or short tubes not a HUGE difference. People will argue that), 3" y pipe, into 3" cat back. A 2.5" y pipe won't kill you, but those work best with the G92 dual cat set up. So 3" all the way
Old Aug 13, 2012 | 09:36 AM
TKR 88 GTA's Avatar
Engine: HSR 350
Probly not even close lol So the only problem I have with the 1 3/4 headers I already have is they hit the knock sensor on the passenger side so is there a way to take the sensor it self out so it frees up that inch or two of space to allow them to fit. My hedmann's are the 1 5/8 headers so I know I do need new headers lol
Old Aug 13, 2012 | 06:10 PM
Guest
Guest
Posts: n/a
1 5/8" is not bad at all. Most street cars run them. As for removing the knock sensor, I am unsure. I am still trying to learn what will and what won't throw the car off due to the computer. Someone will know if it will throw a code. I bet it probably would.
Old Aug 13, 2012 | 07:39 PM
TKR 88 GTA's Avatar
Engine: HSR 350
1 5/8" isn't bad for the afr heads? And well as far as the knock sensor goes it was removed through the computer so nothing will happen if I disconnected it lol I just don't know whats on the other side of it or anything like that lol I know knock sensor just controls spark advance and retard based on what's going on in the engine, and I was told with a cam that would give problems so I had it deleted through the computer.
Old Aug 13, 2012 | 07:40 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
1 5/8" well be fine for you.
Old Aug 14, 2012 | 10:15 AM
TKR 88 GTA's Avatar
Engine: HSR 350
Ok so with shorty headers that are 1 5/8# 3" inch dual exhaust all the way through would best or the y pipe way 3" all the way through?
Old Aug 15, 2012 | 06:02 PM
Guest
Guest
Posts: n/a
For your needs 3" dual would not be worth the trouble. A full, single 3" exhaust will flow plenty
Old Aug 15, 2012 | 06:57 PM
Edwardgp's Avatar
Engine: 454-350
Lets get some pictures.
Old Aug 15, 2012 | 08:15 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
I had 1 5/8 shorty hedmans with dual 3" cutouts, and ran a 11@124mph.
That exhaust will be fine for you
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
