header question. car or engine type??
Old Aug 27, 2012 | 09:51 PM
blackgloves's Avatar
Car: 1987 IROC-Z
Engine: 6.2L
Transmission: Stage III T56
I'm about to buy a 87 IROC. It has a 5.7L TPI out of a 92 Vette in it. Years ago I bought Headman long tubes but never used them. They're still brand new. I bought them for a crate 5.7L called the 330hp crate. It was a vortech motor I believe that had 380 lbs of tq
Will these work on the 87 IROC/92 vette motor??
Old Aug 28, 2012 | 01:02 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: header question. car or engine type??
If they're for a SBC 3rdgen, they should.
Old Aug 31, 2012 | 03:59 PM
JekyllandHyde's Avatar
Car: 87 Trans Am GTA
I've helped install longtubes in an 89 Formula.
It was one of the worst experiences I've ever had installing headers. And the header is still sitting on his driver's side brake line. His ground clearance sucks too. If not for his new springs making his car ride like a 4x4, he would be scraping everywhere.
Old Sep 5, 2012 | 01:31 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
yes, it will work with that engine in that car and ground clearance won't be an issue if they are the same Hedman's i've got on my car- they are less than 1/4" lower than the frame rails. i had to dent one tube on each side to clear the frame, and bent the brake line about 1/2" to get it away from one tube. they slid right in from the bottom with the engine bolted down- i had a big oil filter on it and the starter was out of the car, but there was a ton of room to get a big full size HD starter up in there.i also didn't have the spark plugs in the engine, either, but that's just standard header installation protocol.
i have no complaints at all about the headers themselves- but the stupid way the engineers at GM designed the floorpans of these cars leaves something to be desired.. my y pipe is 3" off the ground where it goes under the trans crossmemberand after 10,000 miles of driving this summer, my 2.5" lead pipes are smashed down to 2" right under the trans crossmember..
Terrell351
Jun 13, 2021 01:13 PM
colton_carlson
Mar 8, 2019 12:21 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
topteam54
LSX and LTX Parts
Aug 11, 2015 07:15 PM
