y pipe question
Old Sep 8, 2012 | 10:12 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
y pipe question
how do you remove the cat from the y pipe? and also on my engine manifolds the y pipe connects to the manifolds using 3 mounting studs off. and the new y pipe i got only connects using two studs. if there anyway i can pull the rotating connector off my new y pipe and add my old ones?
Old Sep 9, 2012 | 07:29 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: y pipe question
That is what I would do, piece it together to make it work.
Old Sep 9, 2012 | 07:59 AM
Engine: L31 350
Re: y pipe question
How can I exchange the the roatating assembly's on the pipes though?
Old Sep 9, 2012 | 08:03 AM
Edwardgp's Avatar
Engine: 454-350
Re: y pipe question
Cut and weld if you have no welder you can get it all ready and take it to a muffler shop.
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
