slp lm2 help
Car: 1986/90 camaro
Engine: 350 tpi
Axle/Gears: 3.73 gears. POSI
slp lm2 help
i purchased a lm2 cat back system and was wondering will it hook right up to the 3rd gen hangers in the back or do i need different ones or modify them? help please
Car: 1989 Trans Am GTA
Transmission: M28 T56
Re: slp lm2 help
Well, that might depend on which version you bought. There is a 3rd gen, and a 4th gen version. And I can't remember if the over the axle side hangers are in the same locations between 3rd and 4th gens..
Call SLP, they should be able to answer that. If you bought it used, do you even know what cat-back you bought? The I-pipes on 3rd and 4th gens are different, they'll work, but require some small pipe fabrication to mate to the Y-pipe.
Car: '91 Camaro Z28, '85 Camaro Z28
Engine: LB9, LB9
Transmission: T5, 700r4
Axle/Gears: Eaton 3.73 Posi, 3.23 Posi
Re: slp lm2 help
They never made a "third gen" SLP loudmouth 1 or 2. But just swap the hangers on the body from side to side or swap in 4th gen hangers.
no green
Jan 9, 2016 09:22 PM
Royal_Z
Sep 30, 2015 08:45 PM
Dragonsys
Sep 25, 2015 03:51 PM
