2 possible exhaust systems?
Old Sep 28, 2012 | 12:34 AM
Austin19's Avatar
Car: 1985 Camaro Z28
Engine: 305 LG4
Axle/Gears: 3.08
I need a new exhaust system for my LG4. I have a set of Hooker 2460 headers (no y-pipe) and a set of Flowtech 11102 headers with 2.5 inch y-pipe. Is it worth it to order in the Hooker 16767 y-pipe to use the Hooker headers or should I just use the Flowtech system? Currently stock LG4, but planning on carb tuning and cam and head upgrades sometime soon.
What is the hp difference between these systems? Would it be noticeable on a stock LG4 or only after the upgrades?
Old Oct 2, 2012 | 08:20 PM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Re: 2 possible exhaust systems?
Bump. I need to know if it is worth it to upgrade between these two options on an LG4.
1) Flowtech headers w/ 2.5" collectors, 2.5" non-upgradeable y-pipe
2) Hooker headers w/ 3" collectors, 2.5" y-pipe with option to go 3"
Old Oct 3, 2012 | 12:17 AM
AmorgetRS's Avatar
Are you sure you don't have Flowtech headers? I am 99% sure Flowmaster doesn't make headers for Thirdgens, or ever has.
Old Oct 3, 2012 | 12:19 AM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Thanks for pointing that out.. they are definitely Flowtech headers. I will edit the other posts.
Old Oct 3, 2012 | 12:58 AM
AmorgetRS's Avatar
On a stock auto LG4 I doubt you'd notice the difference.
Old Oct 3, 2012 | 01:00 AM
Austin19's Avatar
Engine: 305 LG4
Axle/Gears: 3.08
Okay, thanks. One day I'll be looking into heads and a cam. Would I notice a 3" y-pipe then?
Old Oct 3, 2012 | 01:57 AM
AmorgetRS's Avatar
If you are doing heads and cam you would be much better served in starting with a 350 block.
But yes, at that point, you'll probably notice a difference.
92projectcamaro
Jan 18, 2016 08:00 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
makaveli09
Aug 12, 2015 09:07 PM
