flowmaster vs stock
Old Nov 9, 2012 | 07:48 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Transmission: 700R-4
Axle/Gears: 327
flowmaster vs stock
would i notice a big difference in sound by just changing the stock muffler to a flow master 80 series car is mostly stock l-98 only mods are ported runners and plenum UD pulleys with a CAI exhaust is stock with N-10 option
Old Nov 9, 2012 | 08:20 PM
85_ZED28's Avatar
Car: '85 Z28
Re: flowmaster vs stock
Yep, a flowmaster will be much louder.
Old Nov 9, 2012 | 08:28 PM
88 5.7 Iroc-Z's Avatar
Car: 88 Iroc Z, 00 SS
Engine: 5.7 HSR, 5.7 LS1
Transmission: 700r4, T56
Axle/Gears: 3.23, 3.42
its what Im running and its way louder and throatier, definitely a noticeable difference over stock
Old Nov 9, 2012 | 09:03 PM
Phenom-1's Avatar
Car: 1992 Chevrolet Camaro Z28
Engine: 5.7 TPI
Transmission: 700R4 Overdrive Automatic
Axle/Gears: 3.23:1 Positraction
http://youtu.be/QQEY23P1sk
Hell Yeah, Especially in the L98 the Flowmaster 80's Series 3" Catback exhaust is perfect, Especially when your used to the stock muffler, it just brings it to LIFE !!
Old Nov 9, 2012 | 09:05 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
great thanks guys
Old Nov 9, 2012 | 09:09 PM
Phenom-1's Avatar
Engine: 5.7 TPI
http://m.youtube.com/#/watch?v=-QQEY23P1sk&desktop_uri=%2Fwatch%3Fv%3D-QQEY23P1sk
Old Nov 14, 2012 | 12:03 AM
oamhmad's Avatar
Car: 84 Trans AM
Engine: Goodwrench 350 Crate motor
Forget the Flowmaster 80 and go with the 40 series. Much deeper and louder sound. Here is a video:
Old Nov 14, 2012 | 06:38 AM
It'll go from sounding like a car exhaust, to sounding like you're dragging a 55-gallon drum on a 3' chain behind your car 100% of the time.
It'll probably get REAL old REAL fast. I know it sure did when I had one. I. HATED. it. Worst exhaust mistake I ever made on this car.
Old Nov 14, 2012 | 07:06 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I love the way my 80 series sounds at idle. Little more drone then Id like at cruise, but not bad. Not a big fan of how it sounds when you let off at higher rpms though.
Either way, it is up to the owner to decide what he/she thinks sounds the best.
Old Nov 14, 2012 | 08:06 AM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
take out the cat and its even louder.. sounds like my boat
Old Nov 14, 2012 | 09:54 AM
David 91RS/Z28's Avatar
Just throwing in my .02 cents but a great sounding AND performing choice is the Hooker Aerochamber! Just as good of sound but will make more power. It's been documented countless times on dyno's. Check it out if you haven't bought yet!
Old Nov 14, 2012 | 02:03 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
Thanks guys picked up a 80 series for 70 dollars shipped brand new cant wait to it installed
Old Nov 14, 2012 | 02:11 PM
Phenom-1's Avatar
Engine: 5.7 TPI
It will sound even better if its the whole cat back system with 3" pipes as opposed to just the muffler but if your going for a factory look, just the muffler will suffice.
Old Nov 14, 2012 | 08:36 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
trying to keep it stock looking with just the sound also had a hard time trying to find a catback for the n-10 option double cats
Old Nov 14, 2012 | 08:39 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
does any one no were i might be able to pick up a 3" i-pipe for the dual cats i have seen the dynomax version is only 2.5 inches but is mandrel bend does anyone no if that would be better than stock thanks.
Old Nov 15, 2012 | 01:06 AM
Phenom-1's Avatar
Engine: 5.7 TPI
Check with the local muffler shops, you can get pretty much any setup you want, make new piping for a custom fit, if its not in stock piping. Dual cats or single cat.
Those two are the same setup just pictured differently ^
Old Nov 15, 2012 | 01:58 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
cool thanks having it installed on sat I will see what they have and say thanks
Old Nov 15, 2012 | 06:54 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You might want to stay there and take photos of the install process.Its always nice to document modifications like this and keep a few files for your car on the computer.Ive been doing it for over 6 years now and have some really nice photos.
Old Nov 19, 2012 | 02:22 AM
Bbourk89's Avatar
Car: 1989 camaro RS
Engine: 5.0 TBI
Transmission: 700 r4 auto
okay hi to all i have an 89 camaro 305 tbi and i was wondering if i could use the flowmaster 10 series muffller 1 inlet with dual outlets even though its not a crossflow muffler, i intend on hooking the cat pipe to one of the dual outlets and have a pipe running out of the other outlet and another pipe running out of the inlet like the crossflow setups. will this work Please give FEEDBACK!!
Old Nov 28, 2012 | 06:17 PM
Ashton89iroc's Avatar
Car: 1987 IROC-Z
Engine: Vortec 350 crate #12530282
Transmission: 700-r4 Auto
I'm thinking you'll love that 80 series, its what i have on mine. but if it doesn't sound quite as nice as you wanted, just change out your stock pipes...put a new ypipe on mine comported to stock, MASSIVE difference, got that flowmaster sound i was looking for.
Old Nov 29, 2012 | 03:15 AM
Engine: TBI,5.0
So what happend ? I was hoping to get a fallow up on your install.
Old Nov 29, 2012 | 08:33 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
I had it installed and love it much deeper than stock but not over the top I will try and get a sound clip up today best mod so far for the money
Old Nov 29, 2012 | 08:44 AM
Car: 1987 IROC-Z
do you still have all the stock crinkle pipes on there? i had the same set up on my '89, then i got a new y pipe and it just MAKES the sound...i would definitely recommend that, plust those crinkle bends don't allow very good air flow
Old Nov 29, 2012 | 09:26 AM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
for now was looking at the 2.5 inch from dynomax it was all mandrel bend
http://shop.advanceautoparts.com/wcs...4_pri_larg.jpg
Old Nov 29, 2012 | 09:48 AM
Car: 1987 IROC-Z
yup, i used dynomax for my y pipe, ill be swapping out my intermediate pipe like you are with the same thing. if i were you, id get the y pipe replaced first..that way you get better air flow right off the manifolds. then move to the intermediate pipe
Old Nov 29, 2012 | 12:40 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
cool thanks you think that is better than the stock stuff wasn't sure
Old Nov 29, 2012 | 04:41 PM
Shadygrady's Avatar
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
I have run the flowmaster 80 and as mentioned its too loud for me.Maybe thats what you like but i prefer a good mellow sound when im just driving around.I went with the hooker max flow.3' in and out straight through design which is better on performance.It is much more mellow at speed without the droan and i can carry on a conversation and here the radio without turning it up.It is still a tough sonding tone,but when you get on it you can tell its not stock.I swear the butt dyno felt a difference as well.
Old Nov 29, 2012 | 05:05 PM
TNT garage's Avatar
So how do you like it? I went with 1.5 inch headers straight to a fully custom 3inch pipe and purchased a cat back 3inch flowmaster 80 series pipe and muffler with dual 2.5 inch outlets. It really hollers when I put my foot in it and I love the way it sounds at speed .worth every penny. ($79.95 or the headers and $300 for the rest. installed)
Old Nov 29, 2012 | 07:41 PM
89 350's Avatar
Car: 1989 formula
Engine: 350 l98
Axle/Gears: 327
so far with just the muffler stock everything else i love it, i really don't thinks its that loud, especially not as loud as I thought it would have been
Old Nov 29, 2012 | 07:59 PM
Car: 1987 IROC-Z
i agree, inside the car it can drone out a little bit, but thats nothing a crap ton of dynamat won't fix. plus my car has so many rattles and noises (especially on gravel roads) that I've grown accustomed to it being loud inside.
Vintageracer
Jan 10, 2020 05:33 PM
Genopsyde
Oct 7, 2015 08:35 PM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Navy8125
Aug 25, 2015 08:25 PM
midias
Aug 22, 2015 01:42 AM
