85 Iroc Build - Dual Exhaust
Car: 73RS, 85 Iroc, 11 GT
Engine: 383FI, 406 FI, 5.0
Transmission: TKX, TKO600
Axle/Gears: 10 Bolt 3.73s, Strange 12 bolt 3.73
Working on my dual exhaust thought there might be some interest. Primary consideration is for ground clearance as the car will be LOW. Exhaust is just tacked together at the moment as I am working on clearance issues over the axle and not sure about the dual tips yet. Comments and suggestions welcome.
406 SBC
TKO 600
Hawks 1 3/4 long tubes
2.5" tubing
x pipe
home made x member and trans mount
Magnaflow mufflers
Flowmaster tips
406 SBC
TKO 600
2.5" tubing
x pipe
Magnaflow mufflers
Flowmaster tips
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: 85 Iroc Build - Dual Exhaust
Can you get a better picture of your muffler setup? Ive been wanting to do something lke that for a while.
Im guessing you have a custom crossmember for ground clearance?
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
I think flat tips look better on our cars, just my opinion though.
I am traveling for work for a few days so will get a few more pics when I get home. The crossmember is home made and so is the trans mount so that I could raise the x member up as high as possible while still keeping it straight and simple shaped. I also used a short torque arm so that I could get it away from the trans to make more space.
Regarding the tips I am not sure either so that is why I am leaving it this way for
awhile to see if these will grow on me. I think it is either these or will try to hind them
as much as possible
as much as possible
Car: 1992 Camaro RS
The problem with flat tips is getting them lined up. Due to them being square its very easy to see if they're off center or angled a little bit. Hard to build an exhaust system to the perfection that the human eye demands, and then over time they will settle and move a little anyway. Round tips can still be out of alignment and so forth, but its just not nearly as obvious. Plus with rectangle tips, you have to be even more careful than usual about getting both symmetric with the centerline of the car, and you may not have the flexibility under the car to make it happen. Normally the passenger side tip is closer to the center of the car than the driver's side due to the shape of the trunk well.
Thanks for the tip about tips
. I agree and I can already see the difficulty in getting them symetrical about the centerline of the car and the engineer in me gets very disturbed by this. Also with the length of the mufflers I am using and placing them the way I am I have to have a very short tip to fit under the bumper. It took me awhile to find dual round ones that would work. I dont think the rectangular ones would fit.
. I agree and I can already see the difficulty in getting them symetrical about the centerline of the car and the engineer in me gets very disturbed by this. Also with the length of the mufflers I am using and placing them the way I am I have to have a very short tip to fit under the bumper. It took me awhile to find dual round ones that would work. I dont think the rectangular ones would fit. Trending Topics
Few more pics
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
SWEET SET-UP.. THATS EXACTLY WHAT IM AM TRYING TO ACCOMPLISH..
Thanks for the pics.. lol (unsure of x or y pipe)
ambainb
Apr 25, 2016 09:21 PM
mustangman65_79
Aug 11, 2015 03:17 PM
