Opinion on muffler type?
Old Nov 14, 2012 | 05:12 AM
G92Bill's Avatar
Car: 1985 Iroc
Engine: Carb Sbc 350
Transmission: Built 700r4
Axle/Gears: 2000 camaro 10 bolt/ 3.42
Hey everyone, I am finally coming home from deployment! I had my wife put the car in the shop for some minor repair work to get it up and going again before I get home. Anyways when I get home I plan on installing some Hooker 2460's with the Y-pipe, I plan on modifying the y-pipe so I can run a true single 3in exhaust. Not reduced down to 2.5in. I was hoping to get everyone's opinions on a nice deep low sounding cat-back that wont hurt performance. Now keep in mind I would like a deep low sounding idle but I would like to hear the ponies scream when I get on it. So if you guys don't mind giving me your opinion on some options and setups to complement my hooker 2460's. Thanks!
-BILL
Old Nov 14, 2012 | 05:38 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
Re: Opinion on muffler type?
i run this one with shortie headers . http://www.ebay.com/itm/OBX-Steel-EX...sories&vxp=mtr
Old Nov 14, 2012 | 05:43 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
heres my thread of the install an sound clip :
https://www.thirdgen.org/forums/exha...t-obx-cat.html
Old Nov 14, 2012 | 06:18 AM
G92Bill's Avatar
Car: 1985 Iroc
So that came with everything needed to get the pipes to the hooker y pipe? Looks sharp I might add!
Old Nov 14, 2012 | 06:22 AM
G92Bill's Avatar
Car: 1985 Iroc
SOUNDS GREAT! Did you notice any increase in hp from it? Anything?
Old Nov 14, 2012 | 06:24 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
yes all the way to the single cat(you have to buy your own cat ) . it'a polished stainless the whole thing not just the tips .it is getting louder as i get miles on the car . i think it has the second best sound first being a borla .
yes better throttle response. i done the headers an cat back within weeks of one another . an the combo produced the best results .
Old Nov 14, 2012 | 06:27 AM
G92Bill's Avatar
Car: 1985 Iroc
I was looking at pic's. It looks sharp! And yea Borla makes great products. But for 305.00 shipped is a deal!!! Now they 2460 y pipe drops down to a 2.5in. When I get home I plan on cutting that section out and running a true 3in. Are you running 2460's and Y pipe or 2055's?
Old Nov 14, 2012 | 06:41 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I would also recommend looking some sound clips up on youtube of the hooker aerochamber. That might fit what you are looking for.
Old Nov 14, 2012 | 06:56 AM
G92Bill's Avatar
Car: 1985 Iroc
Doing that now. Thanks!
Old Nov 14, 2012 | 06:58 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm running these headers an y pipe right now but i'm about to install obx t3 headers an a t70 turbo an still use the 3" cat back system .
Old Nov 14, 2012 | 07:10 AM
G92Bill's Avatar
Car: 1985 Iroc
Ok. I am sure I can get it to work. I think I am going to run the OBX.
Old Nov 14, 2012 | 07:12 AM
G92Bill's Avatar
Car: 1985 Iroc
I notice you ran a 4.3 serp system. I have one as well. I do not have the AC connected yet. Are those custom lines or did you find them to work from a s-10 or something?
Old Nov 14, 2012 | 11:27 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
everything your talking about came stock on mine
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
the radiater over flow i changed but thats it so far .
Old Nov 14, 2012 | 11:29 AM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
i'm gonna get rid of the ac when i do the turbo .
Old Nov 14, 2012 | 11:34 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Magnaflow 4x9 case may work. Or the dynomax ultraflo series. I had single 4" with ultraflo and i would say it was a deep idle sound. Was loud tho
Old Nov 14, 2012 | 03:07 PM
G92Bill's Avatar
Car: 1985 Iroc
Hmmm weird. I had to convert mine from a v belt setup. Anyways thanks for the feedback. Did you have any issues installing the OBX?
Old Nov 14, 2012 | 03:09 PM
G92Bill's Avatar
Car: 1985 Iroc
Thanks. I will look into it. So far the OBX I am leaning towards. Seems like a good deal.
Old Nov 14, 2012 | 03:37 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
Call Bruce or Stephen at Hawk's Third Gen. They have my old exhaust for my 355. It's Hooker long tube header, 3" Y-pipe into 4" mufflex pipe into spin tech muffer to dual 3 1/2" tips. The whole system has been Jet Hot coated. Great deep power sound.
Old Nov 14, 2012 | 03:47 PM
exhaust system picture
Old Nov 14, 2012 | 07:05 PM
G92Bill's Avatar
Car: 1985 Iroc
Looks good. But I rather piece it together myself. It looks like right after your flanges the piping is slightly crimped or flattened. What was the purpose of that might I ask. I assume for clearance issues but wont that defeat the purpose of the exhaust and work as a choke point?
Old Nov 14, 2012 | 07:20 PM
Its flatten alittle, made that way for clearance under transmission cross member. All Y pipes have the same. The problem is that our cars were not made for exhaust like that. As far as a choke point. it only flatten about about 1/4 to 1/2 in, the coating makes look alot more. I think the only way to get around it is to go with a 2 in Y pipe and maybe it'll fit but alot less flow.
Old Nov 14, 2012 | 07:25 PM
G92Bill's Avatar
Car: 1985 Iroc
The Hooker Y-pipe I have goes from a 3in to a 2.5. I am planning on cutting out the 2.5 in section and welding in a 3in to have a true 3in exhaust. I plan on doing heads and cam upgrades shortly so I figure that I will need the engine to breathe better if I want to achieve 400 crank hp off spray.
Old Nov 14, 2012 | 09:56 PM
freaky's Avatar
Engine: l98 tpi
Axle/Gears: 2.77
only problem with the obx is there clamps suck had to buy my own .
Old Nov 14, 2012 | 10:09 PM
G92Bill's Avatar
Car: 1985 Iroc
Will do!
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
bjpotter
Oct 4, 2015 07:48 PM
