should i block off my egr?
Old Nov 22, 2012 | 05:01 PM
onebadredz28's Avatar
Car: 91 firebird vert
Engine: 305 tbi
Getting ready to install my hooker 2460's and y. also deleting cat. While im at it and getting a computer tune do any of you recommend or not recommend getting a egr block off plate and tuning it out of the computer? Thanks!
Old Dec 2, 2012 | 04:30 PM
BigJon88's Avatar
Car: 88 Iroc
Engine: 383
Axle/Gears: 3.43
Re: should i block off my egr?
Ya block it off make sure you order a plate with a gasket other wise you will have a bad vacum leak
Old Dec 2, 2012 | 05:26 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
IMO the only use for EGR Delete is to hopefully clean up the carbon in the intake and reduce the hoses needed. Really you'd save far more just doing an AIR Pump Delete if you're deleting the CATs. That's various hoses, pulley and pump, and hard lines.
Old Dec 3, 2012 | 02:16 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Unless you're really into cleaning up the engine bay like mentioned. Keep the EGR plug "hooked up" though, or you'll throw a check engine light in your dash. The car isn't smart enough to know it's not there or not, only knows if you keep the electrical connection hooked up.
gta892000
Aug 11, 2019 11:16 AM
sailtexas186548
Feb 17, 2017 03:07 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
