Porting exhaust manifolds
Car: 1989 IROCZ
Transmission: 5 spd
Axle/Gears: 3.45? G92 Option
Been gathering up parts to rebuild the engine in a 89 5spd IROC G92 optioned car. Going to keep it all stock numbers matching(am adding a 400 crank). Anybody ported the stock manifolds and seen any difference in performance. Not looking to make the car a killer but the hot rodder in me is still alive. Thanks
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Porting exhaust manifolds
I doubt you'll see any noticable gains. The manifolds are very poorly designed. If you have the time, it won't hurt, but again, I doubt you'd see any gain if you did a back to back dyno pull.
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
I've been told that cars don't have anything like matching numbers anymore just the casting numbers. All cars with the same motor have the same number.
Car: 89 IROC Z28
Engine: 357 TPI
I was just at Dyno Don's shop. He told me and I check for myself on the 3 or 4 motors he has on stands and believe me the only numbers on the blocks were the casting numbers from the mold and the engine size in liters. He showed me the location where the VIN used to be stamped and the are completely blank. Believe it or not.
Hotrodboba400
Dec 10, 2019 07:07 PM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
