EGR pipework
Old Jan 29, 2013 | 11:31 AM
onemanrace's Avatar
Car: 1988 Camaro IROC-Z
EGR pipework
Hey all,
My '88 IROC-Z has just developed a bad leak from the passenger side EGR connection from the manifold.
I need to order a new part ASAP as she's my daily driver - does anyone know the part number for the plumbing there?
I've attached pics just to illustrate what's going on - the hose clips are a patch by the previous owner, but now the black rubber seal to the piping on the exhaust manifold has given up too.
Old Jan 29, 2013 | 11:41 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: EGR pipework
looks like its the check valve leaking, the air pump pushed air past the check valve into the exhaust. The check valve keeps the hot exhaust gasses from destroying the air pump and diverter valve.
STANDARD MOTOR PRODUCTS Part # AV7
DORMAN Part # 355050
ACDELCO Part # 214417 , 214-417
you can cap it with a NPT: 3/4 cap until you get the part
Old Jan 29, 2013 | 11:45 AM
Engine: Lb9
Transmission: M20
Re: EGR pipework
never mind, you need a sorry it was hard to see in the pic
STANDARD MOTOR PRODUCTS Part # AT144 for the right side
Old Jan 29, 2013 | 01:13 PM
onemanrace's Avatar
Re: EGR pipework
Cheers! That's a huge help for the valve - the plumbing I'm after isn't on the manifold side, it's the rest that runs off back to the EGR on the engine block.
Old Jan 29, 2013 | 01:17 PM
Engine: Lb9
Transmission: M20
Re: EGR pipework
the egr ? The egr on a tpi is fed through a port in the head through the intake manifold to the egr that's under your plenum. The pictures you posted are of the air pump system.
Old Jan 29, 2013 | 01:19 PM
onemanrace's Avatar
Re: EGR pipework
Sorry - that's my mistake! I'm confused between the EGR and AIR system. Apologies.
Yes - the AIR system coming off the exhaust manifold. The tubes on the manifold itself are fine, it's the section after that valve that runs off to the block somewhere.
Old Jan 29, 2013 | 01:21 PM
Engine: Lb9
Transmission: M20
Re: EGR pipework
Old Jan 29, 2013 | 01:23 PM
onemanrace's Avatar
Re: EGR pipework
Awesome - thank you!
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
