longtubes and crossmember clearance
Old Jan 30, 2013 | 10:36 PM
89camaro355's Avatar
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
Just fired my 355 build and started on the exhaust (longtubes) and hit a problem. I have a th350 with a bmr crossmember. The collector is not far from the crossmemember. i was gonna just drop it down around the crossmemeber but then ground clearance issues. Just sitting here thinking I may be able to run a 45 from the collector then just run the exhaust up the side but not next to the car to measure. Just curious if anyone else had this similar set up and what they did?
Old Jan 31, 2013 | 02:47 AM
mnug13's Avatar
Car: 1987 Camaro
Engine: 2.8 V6
Unfortunately I don't have any help for you but I am curious about whether or not you got ot figured out. I plan on running longtubes on my car and a th350.
Posted from Thirdgen.org App for Android
Old Jan 31, 2013 | 09:37 AM
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
Re: longtubes and crossmember clearance
Ill let you know what i do...open headers? lol
Old Jan 31, 2013 | 09:42 AM
mnug13's Avatar
Car: 1987 Camaro
Engine: 2.8 V6
I was reading a thread about longtubes and automatic cars and I didn't see much about people getting around it. I might not have read far enough. I'm think long tubes might be a little overkill for my car anyway.
Old Jan 31, 2013 | 10:15 AM
Car: 89 camaro
Engine: 355 sbc
Transmission: th350
Axle/Gears: 4.56
if you can get away wiith shortys do it because this is an issue. I read some notched the crossmemeber but I had this custom made so not trying to cut up a good chunk of $$$
Old Jan 31, 2013 | 11:12 AM
mnug13's Avatar
Car: 1987 Camaro
Engine: 2.8 V6
Hopefully you can find a way around it after spending the money on a custom crossmember. I'm just putting a fairly stock 350 in mine for now so like I said long tubes aren't completely necessary.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
kammi10
Nov 9, 2015 08:28 PM
91 SrS
Oct 7, 2015 04:32 PM
tmork454
Sep 29, 2015 06:33 PM
