Making a new trans-member for y-pipe
Old Mar 26, 2013 | 11:49 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Transmission: Powerglide
Axle/Gears: Ford 9" with 3.89
Here is my attempt at making my own trans-member so that I can make my y-pipe fit. Going with 3" oval pipe into a single 4".
I am using 3/16 angle-iron and 3/16 flat steel.
As you can see, I am going to have lots of clearance so I can tilt the oval pipes upward to get even more clearance
Here is what the pipes look like from the side, if I tilt them up, there will be lots of clearance.
Old Apr 4, 2013 | 11:46 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Re: Making a new trans-member for y-pipe
Here is my almost finished trans crossmember.
I have to make a few gussets.
Then I have to cut the oval pipes, to angle them up and closer to the th350 trans pan for more clearance .
So I'll have a 3" y-pipe to a single 4" over the axle.
Old Apr 21, 2013 | 01:01 AM
nickyakker's Avatar
Car: 1982 Firebird T/A
looks good, I noticed the princess auto jack stands and took a look and seen you were from Winnipeg, local guy! Is that a aluminum trans crossmember?
Old Apr 21, 2013 | 09:39 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
Not aluminum, its 3/16 flat steel.
Yah, from Wpg.
I go cruising every sunday in the city when the weather is nice.
I go to the track about 3 times a year
Old Jun 1, 2013 | 10:50 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
The crossmember is now complete. I decided to cut the frame to get more clearance so I had to cut and re-weld the crossmember again.
Here is it on the car mocked up with some slip on 45 degree bends.
I have oval 3" piping so now i have to fab up a y-pipe.
Clearance should be awesome!
Old Jun 10, 2013 | 09:47 PM
LB9GTA's Avatar
Car: '91 GTA
Engine: 421sbc
It all finished now
Here's the pics.
So at my lowest point I have about 3-3.5" of clearance.
Maybe some day down the road, I may even try to go true duals with the oval pipe.
With a 3" oval pipe, I save about .75" of height compared to a 3" round pipe.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
hectre13
Sep 8, 2015 03:38 PM
downsouthboy
Aug 29, 2015 11:29 AM
Out-Cast
Aug 22, 2015 07:49 PM
