y-pipe
Old Apr 20, 2013 | 04:51 PM
IVIitchell's Avatar
Car: 91' Formula WS6 Performance
Engine: 305 TBI
Axle/Gears: -
y-pipe
Is there a y pipe that goes out to a 3 inch in order to get 3 in mufflers??? Or what do I do if i just wanna get a 3" in muffler!!!!?????
Old Apr 20, 2013 | 04:55 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: y-pipe
So what your asking is if there is y pipes out there that are 3"out? If so yes they are everywhere. Or are you just wanting to adapt a 3" muffler to the stock exhaust after the rear end?
Old Apr 20, 2013 | 04:57 PM
IVIitchell's Avatar
Engine: 305 TBI
Axle/Gears: -
Re: y-pipe
currently I have an all stock exhaust system (2.5 in 2.5 out all they way from the heads) so i wanna know, if i can get a 2.5 in 3" out y-pipe... That way i can get a 3 in and 3 out muffler....
Old Apr 20, 2013 | 05:21 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Re: y-pipe
you can however you will also have to replace all the exhaust piping to the muffler in the back or if its just the size of muffler you are wanting and are fine with having the exhaust still at 2.5 til the muffler then go to a auto parts store as they have adapters to change sizes from 2.5 to 3. If you are going to spend all the money to put a new y and 3" all the way back you should get cheap headers and /or dual exhaust.
Old Apr 20, 2013 | 08:35 PM
thirdchance's Avatar
Car: 1991 R7U Z28 1LE
Engine: LB9
Axle/Gears: G92 3.42 Truetrac
Re: y-pipe
There are several nice y pipes out there including the stock L69/LB-9 pipe. But I believe you have to use the larger GM cast iron manifolds in combination with them. I did. MAC has a good looking one haven't tried it...cheers,
I'm a former header user!....lol
Old Apr 20, 2013 | 08:38 PM
Engine: LB9
Re: y-pipe
Sorry, the 3" outlet ones above I mentioned go into a 3" highflow cat and then to your choice of 3" system after that..
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
Camaro_383
Sep 11, 2015 11:28 PM
hectre13
Sep 8, 2015 03:38 PM
Out-Cast
Aug 22, 2015 07:49 PM
