how much horsepower do you think this is costing me?
Car: 88 GTA "Cocaine"
Engine: 350 tpi
they used 2 1/4 inch pipe because they said they could not bend the 2 1/2, like I wanted, so the 2 1/2 inch collectors go into bent 2 1/4. it is flush on the backside of the y pipe but the areas that I have taken pics of are just fill in weld because the collector would not fit into the y pipe they made.
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Re: how much horsepower do you think this is costing me?
a shop did this?
If so i'd take it back and demand a refund. that's unacceptable.
The biggest issue i see is not the pipe size, it's the welding quality.
Second is the way they Y'd the system.
Third would be the pipe size..
I'd demand a refund, then buy an aftermarket Y pipe and install it, then have a different shop weld it in to the rest of the system.
Engine: 350 tpi
how much horsepower do you think I will gain with this
http://www.summitracing.com/parts/ho...w/make/pontiac
Car: 1991 Camaro Z28
Engine: 350 tpi
I think that its good for 20 horsepower and 20 foot pound of torque to go from a badly bent up 2 1/4 inch setup to a mandrel bent 2 1/2 inch y pipe
Just for the record, a friend stuffed an LS6 big block chevy in his 3rd gen Camaro and has 3" duals fabricated from headers to rear bumper.
Dual 3" over the axle, granted, it was a super tight fit, but your shop is telling you that 2.25" is all there's room for?
Engine: 350 tpi
so $12.5 dollars a horse power does not sound bad but I spent 285 for the Y pipe which they kept at 2 1/4 all the way to the catalytic convertor. then ran 3 inch after the cat. the hooker areochamber muffler sounds so week and the power is not there because my engine is not breathing right. the intake is a ported upper plenum, ported slps, ported lower intake. ported 305 heads with 194 valves so I have like 10:1 compression. lt4 hotcam, hooker headers and it just seems like there should be more power to be had and the muffler is soo quiet. that 2.25 crap has to go.
Engine: 450HP 355
Transmission: TH350
It is hard for a shop to bend 2.5" through the stock routing, it's much easier for an aftermarket company that has a CNC mandrel bender to get it right.
About 15 years ago i had a shop tell me the same thing on my '82 T/A. Years later I went from a similar 2.25" Y pipe and shorty headers to 2.25" TD's and longtubes. It was truly a night and day difference.
You can pick up some mandrel U bends from Summit, some flanges and a case of beer for a crafty buddy to make something for you. It's not that hard, just takes time and the right tools.
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
I am not sure what is worse the merger or the 2.25
T mergers suck.
T mergers suck.
Engine: 350 tpi
I am gonna see if I can get the exhaust shop to at the very least put the new y pipe on for me.
the junction at the back of the y pipe, right after the two pipes become one, I want 3inch to my catalytic convertor. right now there is 2.25 going into a 3 inch cat
See if they can get rid of the T merger and do something like this
Engine: 350 tpi
that is exactly what I am buying
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
That looks alot like the job that was put on my car. Dont know who done it. I had it fixed quickly.
If you think it looks bad on the outside, wait until you look in the inside. Mine had about a 1" hole torched into it. Thats all.
If that was the best that I could do, I wouldnt even do it.
Glad I clicked this thread. Needed a good laugh today. That is a miserable repair. I can make a better exhaust repair in my garage with a hatchet and elmer's glue.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why not buy $100 worth of bends and weld up your own?
In this picture, I tacked it in place then took it down to the bench, grinded my tack welds and fully welded each connection. It's 2 1/2" into a flowmaster Y collector which is 4". Then I reduce to a 3" catback.
https://www.thirdgen.org/forums/atta...e-slp-4_sm.jpg
-- Joe
-- Joe
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Damon
Sep 26, 2015 04:29 PM
dbrochard
Sep 25, 2015 04:56 PM
