Bolt for Hooker 2055's
Old Aug 10, 2013 | 07:05 PM
Vertigo107's Avatar
Car: 86 ASC Convertible #90
I've been searching with zero results.. I'm looking for either a part # for the 2055 install bolts, OR if someone has a description of what is used on the driver side to mount the a/c bracket correctly, I would be greatly appreciative!
Thanks!
Old Aug 10, 2013 | 08:43 PM
Joe Tag's Avatar
Re: Bolt for Hooker 2055's
Use your original bolts with a spacer. This is not much more than a thick walled pipe that makes up the difference between the headder flange and the exhaust manifolds thickness. You can make one from a 3/8" I.D. Galvanized water pipe. Measure the thickess of the headder flange and the manifold to see how long to make it. Been a while since I've done mine, I forget.
Old Aug 10, 2013 | 09:23 PM
Vertigo107's Avatar
Thanks, ill take care of it in the am!
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
