4" For Fun
Old Aug 20, 2013 | 01:52 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Engine: TURBO 94 LT1
Transmission: T-56 6 Speed
Axle/Gears: 10 bolt 4.10
4" For Fun
So I've been missing for quite a while on this board. (Married, kid, house, remodeling etc. )
I finally pulled the Camaro out of almost four years of storage and fixed all sorts of small things.
Then I felt with having the 70mm Turbo online it was time to ditch the Cobbled together exhaust I hade before for some 4"
The system is comprised od a few U / J bends, one straight piece, a left over diesel muffler, and a 3 - 4" adapter.
I figured I could throw it up here and just mention its really not too hard to make.
Old Aug 20, 2013 | 02:24 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4" For Fun
Turbos like bigger exhaust looks good
Old Aug 20, 2013 | 03:00 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Re: 4" For Fun
That 4" actually is probably lighter than the old one.
Old Sep 7, 2013 | 05:23 AM
padak's Avatar
Car: '87 Trans Am
Engine: 5.0L-V8
Axle/Gears: 3.23 - Posi -10 Bolt
Re: 4" For Fun
Wanna sell those exhaust tips?
Old Sep 11, 2013 | 10:05 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: 4" For Fun
Make me one, I'll provide the muffler and pick it up.
Old Sep 11, 2013 | 03:55 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Re: 4" For Fun
Bring me the car and the muffler i'll do it in on a saturday
The only reason I say bring the car is cause its such a tight fit and I don't want to take my exhaust off just to match it.
Old Sep 11, 2013 | 04:29 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Re: 4" For Fun
So you welded that on the floor and somehow managed to snake it over the axle in the car? If so I'm impressed.
Old Sep 11, 2013 | 04:37 PM
Twin_Turbo's Avatar
Re: 4" For Fun
it looks like there is a slip fit connection where it kicks up in front of the axle
Old Sep 11, 2013 | 05:38 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Re: 4" For Fun
Spot on there.
You can see where the pipe is "buffed" at the weld joint just before the axle that's where the slip fit is.
Old Sep 11, 2013 | 06:23 PM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Re: 4" For Fun
Looks nice take a vid of how it sounds!
Old Sep 11, 2013 | 07:35 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: 4" For Fun
Do you think you can make me one without muffler (straightpipe)?
Old Sep 11, 2013 | 08:36 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Re: 4" For Fun
I'll try this weekend. Its actually pretty quiet due to the turbo.
Your the third person to ask me that. If I get a few more maybe I'll make a weekend out of it and build a few systems.
Dirt cheap of course compared to mufflex
Old Sep 11, 2013 | 08:48 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: 4" For Fun
Heck yea. If u decide to do it put me on the list.
Old Sep 12, 2013 | 12:19 AM
Keoman's Avatar
Re: 4" For Fun
Where did you acquire your tubing? Approximate cost?
Old Sep 12, 2013 | 09:21 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: 4" For Fun
Awesome, I will have to bring it next spring. The car is currently in the process of an LS swap.
Old Sep 12, 2013 | 09:26 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Re: 4" For Fun
Hawks makes a 4" catback you can adapt to a thirdgen. No muffler, over axle and dumped..and 400$ for it
Old Sep 12, 2013 | 04:41 PM
Slick89RS's Avatar
Car: 89 Camaro RS
Re: 4" For Fun
I would have to look up all the parts I used again.
Also, I have a wholesale tire and exhaust supplier. So what I pay and what you can get it for might be a bit different.
Old Sep 17, 2013 | 06:51 PM
bvahnee's Avatar
Re: 4" For Fun
Also interested in a setup if you decide to make a few. Ive got a 454 single turbo that right now kicks out behind the front tire. Ive got some a long straight piece already so I would really only need the bit from just past the straight to the back + a very quiet muffler.
If its prices around a couple hundred for just that I'd be a buyer ASAP.
Old Sep 20, 2013 | 09:49 PM
bvahnee's Avatar
Re: 4" For Fun
http://item.mobileweb.ebay.com/viewi...d=380527342884
For the OP, this may be a good kit to start with then modify for the third gens on the cheap. I just ordered one to see how much modding it'll need. I'll keep you informed.
grngryoutmyway
Oct 18, 2016 05:48 PM
no green
Mar 3, 2016 05:19 PM
Quzyle
Oct 15, 2015 03:35 PM
92projectcamaro
Sep 29, 2015 07:07 PM
