egr system
Old Aug 31, 2013 | 04:29 PM
murphy8711's Avatar
egr system
okay guys i need a little help here does anyone know how the egr system is ran im trying to figure out how it works so i can make mine functional again as previous owner eliminated it
Old Sep 7, 2013 | 07:09 PM
murphy8711's Avatar
Re: egr system
bump
Old Sep 9, 2013 | 01:51 AM
8T9Formula's Avatar
Car: 1989 Formula
Engine: 5.0
Transmission: 5 sp
Axle/Gears: 3.45:1
Re: egr system
Knowing what you're working on might allow more detail; but in general there is a vacuum actuated valve on the intake manifold that allows meaured amounts of exhaust gast into the inlet stream. The vacuum source for the valve is controlled by a solenoid that is activated by the engine ECU during part throttle. If the previous owner removed the valve you will have to replace it, the control solenoid, and any/all of the associated plumbing and electrical wiring.
I HIGHLY recommend getting a factory service manual to help you figure out what is supposed to be on your particular engine...
Hope that helps you!!
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
92firebirdguy
Sep 1, 2016 07:53 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
Kenwood
Sep 11, 2015 12:50 PM
rjcme
Sep 5, 2015 01:23 PM
