exhuast leak
Old Sep 2, 2013 | 01:15 PM
DiabloWS6's Avatar
Car: '86 TRANS-AM WS6
Engine: 1989 355 TPI L98
Transmission: TH700R-4
Axle/Gears: BorgWarner 9 bolt/ 3.27
exhuast leak
I have an exhaust leak coming from the passenger side of the engine i tighten the header bolts i also did a needle nose pliers holding a small piece of paper but could not determine were the leak is coming from i noticed a small leak behind the intake manifold to engine block below distributor area could that be my cause of exhaust leak or what other tips can i use to determine my exhaust leak
Old Sep 2, 2013 | 02:05 PM
ghost91's Avatar
Car: 1991 Camaro Z28
Re: exhuast leak
Using periods are your friends. check your header gasket..
Old Sep 2, 2013 | 02:26 PM
DiabloWS6's Avatar
Re: exhuast leak
Sorry for not using period i got carried in my train of thought. I double checked the gasket before but the leak/sound comes from below i think either header collector or behind engine/manifold.
Old Sep 11, 2013 | 07:21 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: exhuast leak
welcome to the wonderful world of headers!! where exhaust leaks are free ,but the fix isn't!!
Old Sep 11, 2013 | 06:01 PM
DiabloWS6's Avatar
Re: exhuast leak
that is true
Old Sep 16, 2013 | 01:28 PM
rs coastie's Avatar
Car: 91 camaro rs
Engine: tbi 305
Transmission: 5 speed
Re: exhuast leak
that is true
Are you running long tubes or shorties?? you could have a leak coming from the Y pipe if ya got shorties. Ahhh header leak noise, its annoying.
Old Sep 16, 2013 | 05:14 PM
DiabloWS6's Avatar
Re: exhuast leak
Im running slp shorties with matching y pipe. Im almost positive its coming from the y pipe . The header bolts are tight, but the noise is coming from the right bank below the header.
Old Jan 2, 2014 | 11:37 PM
DiabloWS6's Avatar
Re: exhuast leak
I figured it out its the no. 8 exhaust on the header an exhaust shop is going to take care of that for me
Old Jan 2, 2014 | 11:46 PM
Joe Tag's Avatar
Re: exhuast leak
Copper gaskets are less likely to blow out again. Cost a little more but save a lot of aggravation. Also locking header bolts.
Old Jan 3, 2014 | 12:23 AM
DiabloWS6's Avatar
Re: exhuast leak
And can be used again copper gasket and have been looking into the locking header bolts well see as soon as the paycheck and saving up goes on
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
